RC injector O-ring leak
Old Jun 8, 2010 | 01:38 PM
boardriderxxx's Avatar
Default RC injector O-ring leak
Did anyone have a problem with there RC injectors leaking gas at the top O-ring? It's been about 3k since I put them in and the one just started to leak. Can I find these O-rings at autozone or do I have to order them.
Old Jun 8, 2010 | 02:00 PM
trd07tc's Avatar
try OEM
Old Jun 8, 2010 | 03:32 PM
m6ar2cel6oTC's Avatar
You har yo use oem o rings not the ones provided with the injector.
Old Jun 8, 2010 | 08:48 PM
DezodDon's Avatar
Also be careful because they are shorter than OEM. Only slightly. I have seen this on a few cars. If they are fully seated in the rail they will be a major boost leak at the head. What I have found that works well is to use lower o rings from an 80s IROC camaro (with TPI engine) Just double the lower o ring up and it will seal as well as push the injector further up into the rail ensuring a seal on both ends.
SloTC1
Aug 16, 2018 02:45 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
