Eyelid Help!
Old Jun 26, 2010 | 06:14 PM
Too Offset's Avatar
Default Eyelid Help!
So I bought me a pair of eyelids for my tC.
However, I'm a huge failure and messed up my first eyelid in a about 45 seconds...
I know alot of people on here have eyelids and I was wondering if you guys could offer me some help/advice. Cause I really don't wanna mess up AGAIN.
A tutorial would be awesome. ;)
But anything is appreciated.
Thanks!
Old Jun 26, 2010 | 06:27 PM
yellowxhoodie's Avatar
vinyl im assuming?
spray a soap and water solution onto the the headlight first, then apply the vinyl and use a squeegee and blow dryer to get the water out from underneath.
Old Jun 26, 2010 | 06:32 PM
RoboCop's Avatar
Do as yellow said. Sometimes you have to reset it and use the hairdryer to heat the vinyl and stretch it. I did a dual layer and it is the most annoying thing ever. Having to put a vinyl ontop of another vinyl was not fun at all.
Old Jun 26, 2010 | 06:47 PM
Too Offset's Avatar
Thanks for the feedback.
One problem I noticed when I was trying to put the eyelid on, was that the headlight would dry up really fast.
And the stretching the vinyl part was a pain. -.-
Old Jun 26, 2010 | 06:58 PM
its should need to be stretched all that much.
like i said, spray the soap and water on there, its so that you can move the vinyl around and get it in the right place.
Old Jun 26, 2010 | 08:02 PM
RoboCop's Avatar
It's best if you have 2 people. One working the vinyl and the other with a spray bottle with a soapy water mixture with a hairdryer. Just have the other person keep spraying the headlight. It does seem to dry pretty quick at this time of year.
Old Jun 26, 2010 | 09:19 PM
Eleanor_tC05's Avatar
when I did mine I just let my car sit out in the sun for about 2 hours so the surface would get warm, I didn't really need the blow dryer then. When I sprayed the soap/water mixture I SOAAAKED it and just held the vinyl where I wanted it and squeegeed. Either way works but it just takes practice.
Old Jun 26, 2010 | 09:27 PM
you dont use the blowdryer so the surface is warm...
you use it so the vinyl heats up and becomes a little more flexible, that way you dont get creases.
Old Jun 26, 2010 | 09:37 PM
yeh it works the same way though once you lay it across the headlight. Im just saying I didnt need it..
Old Jun 26, 2010 | 10:01 PM
Too Offset's Avatar
Yeah, I think I'm gunna have my friend help me out this time, haha.
Also, when I finally had it in the place I wanted it, stretching it out would just move it out of place...
Which is always fun..
Old Jun 26, 2010 | 11:37 PM
RoboCop's Avatar
Ya you have to learn how to get one area completely dry and let it cool that way it actually sticks and the adhesive isn't loose. When I did the double layer, the top layer was instantly sticking to the bottom layer even if it was wet sonwhen I peeled up the top layer to readjust, the bottom layer would come up to...
Old Jun 27, 2010 | 01:43 AM
egobuster1's Avatar
it takes practice and patience. i did the tail lights of my old car with vinyl and i used windex and sprayed a bunch on in one area and worked that one area with a heat gun so it would stretch and once i got that one area on nice and tight i then worked on stretching the vinyl all the way across and stuck it on nice and then went back and adjusted what needed to be adjusted
yoson13
Scion xA Aero & Exterior
Aug 30, 2015 07:38 PM
terrye
Jan 11, 2015 10:00 PM
y0itzduy
14
Oct 13, 2005 04:26 PM
peterbilt
23
Jun 7, 2005 12:29 AM
