Question - mix stock wheels with 19" TRD ones
Old Feb 26, 2005 | 03:18 PM
NJ_05tC's Avatar
Default Question - mix stock wheels with 19" TRD ones
I hit a huge pothole last night on 287 southbound. The 19" TRD wheel is damaged. My tC now has 2 front stock 17" wheels and 2 rear 19" TRD wheels running (i know, it's funny looking ). Do you think it's going to cause problems?
Old Feb 26, 2005 | 04:02 PM
i64X's Avatar
Just put the 17's all back on it. You'll look like someone that can only afford two rims driving around with two stockers and two 19's.
Old Feb 26, 2005 | 04:35 PM
ChefRaekwon's Avatar
You won't have any problems if its not for a long period of time. Later down the road your alignment is probably off due to a hard hit like that so you could wear ur tires out very quickly.
Old Feb 26, 2005 | 05:05 PM
brian's Avatar
just put 17s all around til you get it fixed
Old Feb 26, 2005 | 05:06 PM
dgHotLava's Avatar
Old Feb 26, 2005 | 05:40 PM
LiquidXB's Avatar
Just go get a rubber or plastic hammer (dead blow) and give the bend some good whacks.. It should bend back to somewhat normal. I used to work for a custom wheel shop and that is what we did and we never had problems. Good luck!!
Old Feb 26, 2005 | 07:00 PM
GT4Dreams's Avatar
insurance won't cover?
It will look kinda cool I think, making the car have a more aggressive stance, but then people will think you are trying to make it RWD
Old Feb 26, 2005 | 08:22 PM
bambams247's Avatar
post pictures of it with both wheels on i wanan see!
Old Feb 26, 2005 | 08:35 PM
chris0's Avatar
me too!
Originally Posted by LiquidXB
Just go get a rubber or plastic hammer (dead blow) and give the bend some good whacks.. It should bend back to somewhat normal...
ummm...maybe you should keep the speed down if that's how you fix it.
chris
Old Feb 26, 2005 | 09:34 PM
NJ_05tC's Avatar
Here is a couple of quick ones...too dark outside...i'll have more tomorrow...
Old Feb 26, 2005 | 09:53 PM
LiquidXB's Avatar
If you do it right you can fix it perfect. I've done this to tons of 17,18,19 inch wheels and when i was done i would throw them on a balancer and the bend would become almost undetectable!! If done right you should have no prob, I've been doing this for a long time. Just hit it and check it hit it and check it and so on till it looks like it should.. Or take it to a pro.. Good luck!!!
Old Feb 26, 2005 | 11:05 PM
bambams247's Avatar
Thats looks funny as hell, lol. Put both 17s on and then go get the 19s fixed, any wheel shop should be able to do it no problem!
Old Feb 26, 2005 | 11:07 PM
tekniq's Avatar
I wouldn't do that without applying heat first. When aluminum bends in one direction without heat it becomes brittle, bending it back will amplify the effect. I did the exact same damage to my stock 17" rim and I used a 6ton press and a oxygen-acetylene torch with a rosebud tip to heat it up briefly and bend it back with the press, then I used a tig welder to strengthen the areas I heated because they began to puddle briefly. Re-applied clear coat finish to the aluminum and the wheel even balanced out with the same weight that came on the tire from the factory.
It turned out pretty true to the eye, however I filled it up with 49psi and its down to 44 a few weeks later. Keep in mind its Minnesota, so we've had sub zero temperatures and warming back up... It lost about 3psi more than the other tires that were not damaged. For being a free repair I deem this acceptable.
Here's a shot of what the pothole did to my wheel:
Good luck with your repair! If you have any questions about what I did, PM me.
Old Feb 26, 2005 | 11:41 PM
unlmtdndeavor's Avatar
wow...i wish i knew how to fix wheels and had access to that equiptment. although seems like a lot of work when it can be fixed at a shop for under $100. good work though
Old Feb 27, 2005 | 03:39 AM
tekniq's Avatar
there is only 2 shops that I could find that would fix wheels in the twin cities, and they both admitted to sending them out. $250 was the lowest estimate and they said it would be 2 weeks. .. So I did it myself ;)
eric_m
52
Jan 17, 2019 05:50 AM
2CTC
Sep 12, 2015 11:33 AM
scionlife
371
Jun 2, 2015 11:00 PM
Beesh
Jan 9, 2015 06:30 PM
