Who you are? where you run? And whats your set up?
Well i am starting this thread to see everybody who participates in auto cross, track racing, drag racing on a regular basis with their scions. So fill it out and ask questions so we can get this section of scion like alive.
Questions.
Who are you?
What type of Racing and organization do you compete in.(scca..etc..)?
Whats your current setup?
What are your plans for it?
a pic if you have one.
Questions.
Who are you?
Well i am atomsk. we will stick to that right now. I am currently a college student at OU studying engineering. I have participated in legend car racing before and have finally moved up to auto cross and track racing at the sheriffs training track in okc.
So like i said i participate in the track days with the BMW and Porsche clubs at the sheriffs test track. I got keep those guys that spent 50k on there cars inline.
current setup.
08 tc.
cross drilled and slotted rotors.
full exhaust
headers
sw short ram air intake.
dg 25mm rear sway.
future plans.(next year)
removal of back seat.
new tires and rims.
ss brake lines
new temp gauge ( lower to help out that cooling)
front and rear struts.
current setup.
08 tc.
full exhaust
headers
dg 25mm rear sway.
new tires and rims.
ss brake lines
current setup.
08 tc.
full exhaust
headers
dg 25mm rear sway.
new tires and rims.
ss brake lines
current setup.
08 tc.
full exhaust
headers
dg 25mm rear sway.
new tires and rims.
ss brake lines
I'm Tony Cambio, Scion Champion at Oakbrook Toyota-Scion in Westmont, IL
The car is a 2006 xA prepared for SCCA Street Touring autocross. Currently #2 in Chicago SCCA, which is my goal for 2010
Power Mods:
Injen RD CAI (not a big fan - would rather have a normal CAI like K&N, etc.)
Spectre open-ended filter with a stainless shield (I'm missing half my inner fenderwell...)
Strup Stainless & Ceramic header. A SHOWpiece. I feel bad that it's on the back of the motor...
Supertrapp tuneable muffler. I LOVE these. I can tune the muffler so I don't lose the lower end, or I can open it up without crawling under the car. It also gives an incredible sound for 1.5 liters.
Handling Mods:
Bridgestone Potenza RE-11 tires - 205-50-15 (actually an inch undersized, but that's what they offer & they WORK)
Enkei RPF-1 - 15x7 40 offset (I ordered 35 from Edge Racing & they sent 40. No wonder I needed rear spacers with 225 tires...)
Progress rear anti-sway bar (eventually to be replaced by a NASCAR-style bar for batter rotation)
Koni Sport Dampers(One of the best things I did for handling)
H&R Race coils (A hair stiffer than Eibach Sportlines)
Other Mods:
Schroth Rallye 4pt harness
Generic POS short-shifter
Power Mods:
Handling Mods:
Other Mods:
Not with a DG sway (by SCCA rules anyways). The only sway you can run and stay in stock is the TRD, and that is only on the 07+ I think, when they started offering it as a factor option rather than a dealer option.
I autocross mine here locally.
ST Prepped
Tein SS-Ps set on approx 1.4 inches of drop
Corner balanced
Camber: -1.5F/-1.25R on the street and -2.75F/-1.25R at events
DG Rear sway (full stiff for events)
Hotchkis strut tie (does practically nothing on this car .. )
Potenza RE-01Rs 225/45/17 for autox and boring so-so Falken 912's on the street. Will be getting Star Specs when the 01R's are done this season.
Doc I Short shift
A few non performance mods too.
My next goal is to get the time to tear it apart and finish the calcs to complete design of another set of coilovers. Looking to probably go with koni's customized for coilover sleeves, hypercoil springs and either modify my current camber plates to work with them or have some new ones built.
Grew up in OK myself, but moved to MN after grad school for work. Not a huge fan of the winters, but I think we are spoiled as far as autox events. I haven't talked to many people who's region managed to run events with 160 cars getting 6 or so runs through 70 sec + courses
They have been doing it since before the SCCA existed and have a good number of nationals contenders each year, so they have gotten pretty good at putting on good events.
ST Prepped
Corner balanced
Doc I Short shift
engifineer is right i do not run in the stock class. i run in the st. Most of the time i run at a different track that is non scca. So we don't even have classes, this is just my addiction. If i want to race too much i will go back to legend cars.
You could go with TRD springs too. They dont over drop like most crappy (for handling) aftermarket springs do these days and did really well for me in autox when I ran them. Still a good ride on the street too if that is an issue.
i am trying to save up and get a pair of progress. I am doing my math on what rates i should run or i could buy the dg spec ones if there are any left by the time i get them money. But i am afraid of the spring rates might be to high to have the car on the streets in Oklahoma.
i'll play...
type of racing: drag racing. so far i have only raced in the import face-off forced induction pro class.
my current set-up: 2006 scion tc, built short block, stock head, dezod aem ems, dezod return fuel system, rc 650cc injectors, aem meth injection, turbo toyotas equal-length manifold (original version), 3" downpipe and full exhaust, garrett t3 60-1 .82 a/r turbo, hks ssq bov, tial 44mm wg, pwr intercooler, competition clutch stage 5 clutch, m&h 25.5x8.5x15 slicks, 19 psi, 7200 rpm redline, 417whp/366ftlbs, best pass of 11.70 @ 124 mph. (on 17 psi)
plans: i plan to get a 10.xx pass next time out to the track. after that, a fully built top to bottom motor and gt42 turbo go in and 9 second passes.
pics:
pics:
You guys all have really awesome setups... I dig it
I'm Tyrone.
I run my 2006 xA locally here in Omaha at SCCA autocross, TSD Road Rally, and Fast Friday/Lapping at Mid America Motorplex.
Current Setup:
EBC Slotted Rotors
Hawk HPS Pads
TRD Rear Sway, Springs, Struts
Falken Azenis RT-615K
Enkei RPF1
Miscellaneous Engine Stuff...
Tony, what is the difference between the Koni Sport Dampers and H&R Race coils? I may be getting my terminology mixed up, is one of them springs and the other shocks or is the H&R coils your coilovers? I'm currently not happy with my TRD setup and would like to look into better suspension setups.
I'm Tyrone.
Current Setup:
EBC Slotted Rotors
Hawk HPS Pads
Enkei RPF1
I'm Tyrone.
Current Setup:
EBC Slotted Rotors
Hawk HPS Pads
Enkei RPF1
I'm Tyrone.
Current Setup:
EBC Slotted Rotors
Hawk HPS Pads
Enkei RPF1
The Konis are the dampers (struts/shocks) and the H&R's are the coil springs
engifineer,
How's the fit of the slightly oversized 225's?
The 225's are a perfect fit on a 7 inch rim and are the max allowed for ST. I would definitely recommend running them.
usc:
How do you like the 615k? Have you run the RE-01R's, RE-11's, old RT615's or Star Specs for comparison? I was very curious to see what the new generation of the 615 would be like, but I think they priced themselves out of the game. The original in its day was one of the street tires to have in autox and stayed for a long time due to its price. To get better performance you had to spend significantly more. Now, they are priced near the RE-11, which I have a very hard time believing the can compete with. And for much less you can get Star Specs, which are an amazing tire for autox. I just cant see how they are going to stay in there with their current pricing unless they compete worlds above the previous version.
usc:
usc:
usc:
I used to run the old 615's and they were great tires, but others have surpassed them by a good amount and they just arent that competitive like they used to be.
Taking longer to get warm is a good thing though for the 615. The older ones had a tendency to heat up quickly and then get greasy if they got much warmer. So when they really got hot they would start to loose traction.
But I went from the 615 to the RE-01R's and it was a big improvement. The RE-11 is a big improvement even over the 01R. So the old 615 just wouldnt do it any more. They would be perfectly fun for aggressive street driving, but tire life is low on them.
I will be running the Star Specs next. The 11's would be a tad better, but for the price the Star Specs are the way to go I think. If I were running Nats then I would be willing to spend top dollar for a couple of tenths on course.
Sounds good engifineer...looks like I'll have to give the RE-11's a shot. The 615's will be done by the end of the season. I'll just have to keep an eye out to see if I can catch some specials on the RE-11's somewhere.
By the way, your autocross events sound awesome by the way you described them. Can you give me a link to the schedule? I may be tempted to drive all the way up there to try one out. Google maps says its 6 hours away from here. I may just spend a weekend there sightseeing and autocrossing. Is there anything worth sightseeing?
Sculpture garden, museums, mall of america (basically just a tourist attraction, I never go there except to show newcomers how large it is...), then all the outdoors stuff. If you did it we could maybe do a drive around the area on saturday then hit the event on sunday.
If you go to myautoevents.com and search for autocross in MN you can register there. They open registration 30 days prior to the events. COM also puts on some more laid back, fast course events as well. If you like the longer courses, look for our events at DCTC (Dakota County Technical College) and our last couple in Oct at Canterbury park.
