Fast Idle Switch
Old Aug 4, 2010 | 03:42 AM
buickid's Avatar
Default Fast Idle Switch
Well my 320A alternator doesn't put out enough at idle, and holding the gas pedal down all the time while giving out demos gets to be a bore. So searching around, I found something that might be of interest!
On the YotaTech forums, they do this "ECT Mod" for slightly more power. ECT is Engine Coolant Temperature. The ECT sensor is basically a resistor that drops in resistance as temperature increases. By adding a potentiometer, the computer is tricked into thinking the engine temperature is lower than it really is, thus increasing the engine RPMs (like when your cold start your car).
More info here:
http://www.yotatech.com/f2/high-idle...anyone-198737/
http://www.yotatech.com/f2/another-n...-ect-mod-5537/
Old Aug 4, 2010 | 03:51 AM
xseveredveganx's Avatar
Utah Scions
Hmmmm... RadioShack has potentiometers...
Also, my buddy running 16volts has a potentiometer...
Hmmmm...
Old Aug 4, 2010 | 04:07 AM
buickid's Avatar
Hmm. If I knew which was the ECT wire going into the ECU I might be tempted to give it a shot...
rrtxdrvr
May 22, 2015 03:58 AM
Xaphoon
Scion tC 2G Aero & Exterior
Apr 26, 2015 07:49 PM
CPL_Radar
Mar 5, 2015 05:42 AM
cid_mcdp
Jan 5, 2015 02:45 PM
