Autosports & Technique
General driving and racing...
5/6 point harness guys...
Old Aug 11, 2010 | 08:12 PM
One-Nut_McGee's Avatar
Default 5/6 point harness guys...
How are you mounting your 5th/6th points on the floor? Are you welding in hard points or doing a drill/tap/install eyelet hole?
I'm about ready to put in my 5pt setup, but don't want to halfass the sub-belt and am having a hard time deciding if I should do a weld in hard point or just do a drill/tap/eyelet setup.
Thoughts? Any pictures of your setups?
Old Aug 13, 2010 | 04:40 PM
...nobody running a 5 or 6pt harness?
What are you guys racing with? 4pts?
Old Aug 17, 2010 | 01:00 AM
Kanchi's Avatar
When I had 5 points I had the sub strap wrapped around the seat bracket but i would use the plate and eyebolt.
Old Aug 19, 2010 | 07:40 AM
Thorium06's Avatar
I have mine wrapped around the seat bracket with some fancy knot I learned from climbing lol.
Old Aug 19, 2010 | 11:56 AM
GQQSE13's Avatar
i think majority are running 3 and 4
Old Aug 24, 2010 | 01:46 PM
oneday's Avatar
Using the plate and eye bolt is your safest and easiest method. Other options are to use the existing lap belt attachment points (if your 5/6-pt leads are long enough) or welding a bracket into place.
The knot method is definitely NOT the way to go...no matter how fancy you think it is.
Old Aug 25, 2010 | 06:28 PM
Yea, I'm pretty sure no matter how I do it the lead for my 5th point is too short to use a stock mounting location. I had assumed a plate/eye setup was going to be the best, just hoping to avoid accidentally doing work that was already remedied in some other fashion.
I looked at my seat rail and tried to fathom a way to tie the belt, but I couldn't see a way to do it that I would trust to support me in a crash.
alexbazzi
Jul 1, 2015 04:58 AM
sere
Scion xD Drivetrain & Power
Mar 23, 2015 03:50 AM
TheTripleC
Jan 4, 2015 06:46 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
