2nd Gen Scion xB Bazooka Amplified Enclosures
Old Sep 7, 2010 | 02:12 AM
SparksAI's Avatar
Default 2nd Gen Scion xB Bazooka Amplified Enclosures
If you haven't seen these before, Bazooka and Toyota teamed up to provide an amplified 8" subwoofer and enclosure for the 2nd Gen Scion xB. It is a pretty sweet setup, it stays out of the way and off to the side, while using factory wiring connections for signal, and power! This means you can add some thump without having to worry about all of the cables, connections, adapters, or even who will install it. This is a perfect setup for the DIY'ers looking to add a little something to make their ride sound a bit sweeter.
You can check them out on Bazooka's website
http://www.bazooka.com/products/mobi...Enclosure-P458
We are also having a special 1 week sale on these, more information can be found here
https://www.scionlife.com/forums/sho...34#post3676234
Old Sep 7, 2010 | 02:35 AM
streetxdreamer's Avatar
old news is old
Old Sep 7, 2010 | 02:43 AM
SparksAI's Avatar
Didn't figure they were very new, but some folks might not have seen them before. Nothing wrong with sharing information.
and old internet meme is old J/K
Old Sep 30, 2010 | 02:27 AM
RicDalek's Avatar
Default Thanks
Been looking for something like this. Does anyone know how easy it is to install?
Old Sep 30, 2010 | 03:27 AM
SparksAI's Avatar
Installation isn't too bad as long as you are comfortable removing interior panels. I would rate the job ar intermediate and should take 2-3 hours to complete. You will need to remove the panel it mounts to and the railing leading up to the front of the car. After that you route the wiring harness to the front and remove the radio, connect the harness and reinstall the radio and railing, drill two holes in the panel and attach the mounting hardware, reinstall the panel and then mount the sub.
Here is the manual. It may look complicated at first but that is because they carefully point out each detail of the install. The instructions are very thorough.
http://www.bazooka.com/pdf/current/1...n_Last_rev.pdf
Old Oct 3, 2010 | 07:33 PM
xtylerx's Avatar
I've never done any kind of stereo work before, and I was able to get it done in a couple hours, no problem.
Old Oct 4, 2010 | 01:22 AM
ocotillo's Avatar
Did you stay at a Holiday Inn the night before?
Old Oct 4, 2010 | 04:33 AM
xtylerx's Avatar
No, not me.
Old Oct 5, 2010 | 09:23 PM
ScionFred's Avatar
I wanted this so badly... in 2007. I had to make my own so now I don't need it.
Old Dec 31, 2010 | 03:04 AM
pkxb's Avatar
Does anyone have this Bazooka OEM sub connected to the Alpine premium audio head unit? I have '11 XB with the Scion Alpine premium audio but having trouble getting the Bazooka sub to work. The connections on the HU match up with the T-connector that came with the sub, but the sub does not seem to power on (light on sub does not come on). The functions on the HU seem to work as per normal but the sub does not come on at all. Any ideas or suggestions would be great.
Old Jan 10, 2011 | 02:53 PM
pkxb's Avatar
Looks like I did not hook up the ground properly. I had to scrape some of the paint off the inside body panel where the ground connection was supposed to go.
Old Jan 14, 2011 | 02:02 AM
goldentoaster's Avatar
Thumbs up
I bought one of these last year and had a local dealership install it. The tech charged me around $100 for the install (worth every penny) and said he probably undercharged. I love the little thumper! fattens up the bottom end nicely without shaking the fasteners loose and matches the stock system well. It is also nice that it takes up virtially no storage capacity in the back.
If you need serious thumpage, look elsewhere, but for the price it's a good deal and works well.
Old Jan 14, 2011 | 02:53 AM
sexby's Avatar
make sure you coat it with some primer or put some vasoline on it so it doesn't start to rust
12thhawksfan
Jul 14, 2015 06:18 AM
posiden
Mar 22, 2015 03:03 AM
kleecker
Scion xB 2nd-Gen Wheel & Tire
12
Dec 31, 2014 04:07 PM
kleecker
Dec 31, 2014 09:42 AM
cwong1001
Dec 3, 2014 03:30 AM
