HELP... Returning S/C tC to N/A
Old Sep 11, 2010 | 03:42 PM
SciMeiji's Avatar
Default HELP... Returning S/C tC to N/A
Hey guys,
Since my ECU is TRD reflashed, i bought another ECU because i heard once u reflash u cant reflash back to NA. Well this new ECU has the same manufacturing date as my old one and looks identicle however the numbers on the lable are different. I called a toyota parts department and he said the numbers have to match and that all ecus are vin specific and that the new ECU will not work. I think hes full of isht. What do u think?
I kno this might sound crazy but will my original trd reflashed ECU work for NA?
Wjat are my options here?
Thanks
Old Sep 11, 2010 | 04:11 PM
GammaTNT's Avatar
I had to buy a new ecu going back to NA. Ptuning did the uninstall for me. You can try to pm them for help
Old Sep 11, 2010 | 06:52 PM
m6ar2cel6oTC's Avatar
You have to have same year ecu of your car and the new ecu has to be the same Tranny as yours and all you had to do is program the key to the new ecu. I did it trust me it can be done. Search on here of the thread on how to program your cat key to the new ecu all you need is a baby clip. Don't listen to the guy at Toyota he doesn't know what he's talking about.
Sent from my iPhone using Tapatalk
Old Sep 11, 2010 | 07:04 PM
Ace83's Avatar
Ronin Scion
^ you did it yourself? how bout a DIY
Old Sep 11, 2010 | 09:06 PM
there is a DIY i think garage1217 had did the DIY. its easy paper clip and put it in one opf the pins on the obdII port and thats it wait for like 30 minutes or something and make sure lights on your cluster are flashing that means its being programmed and thats about it. i dont remember which pins it is thats why i said for him to sewawrch and find that thread.
Old Sep 11, 2010 | 09:40 PM
SciMeiji's Avatar
^^^ Wow good stuff. Its alittle more involved than i had hope but thats no surprise.
Well b4 i read ur posts i returned the entire car back to NA hooked up the junkyard ecu, turned the key and it was a complete FAIL. Car would kick over and die. So we hooked up the TRD reflashed ecu and it started right up. Either A) the ecu is the wrong year, B) the ecu is fried or C) the whole key ordeal as u mentioned. What do u think?
I wish i could just use the TRD reflashed ecu but im sure the fuel its dumping in the cylinders will quickly murder my cat.
Old Sep 12, 2010 | 01:24 AM
thendawg's Avatar
You HAVE to program the key - no way around it - its part of the anti-theft system. I know theres a diy for it somewhere on here
Old Sep 12, 2010 | 04:54 AM
SciMeiji's Avatar
Nice, i found the tsb...
http://forum.autocd.com/download.php?id=3927
I cant thank u guys enough. I truly appreciate it.
Old Sep 12, 2010 | 05:45 AM
draxcaliber's Avatar
yeah, the ECU's aren't programed to the VIN, BUT the part numbers should match. i've swapped my ecu from reflashed back to n/a.
Old Sep 12, 2010 | 06:19 AM
ScionFred's Avatar
I don't see why not, as long as you keep the 410cc injectors. If you switch back to the oe 320cc, it will be very lean in open loop.
yupinmytC
22
Jul 27, 2024 07:08 PM
SloTC1
Aug 16, 2018 02:45 PM
Blunderbuss
Oct 8, 2015 04:56 PM
paisatronix
Sep 5, 2015 04:13 AM
WVXC450R
Scion tC 2G ICE & Interior
Aug 26, 2015 03:15 AM
