HELP THE NOOB! :)
ok so i'm lowered on stechs. would a 18x9 +38 or a 18x9 +15 fit in there WITHOUT rubbing? i daily drive my car so i dont want it to rub. also which set up would look better?
ps. i know there is that tire fitment or w.e. sticky in the wheels and tire section, but since i have no clue about this i cant do nothing with it. Thanks in advance.
Since nobody has chimed in yet, I will give you my guess. If you are on Stechs a 18x9 + 15 definitely sounds like you will rub. +38 sounds aggressive still, you might have to run some neg camber. My guess, and anybody correct me if I'm wrong.
It'll fall under the tucked category but you'd probably still have to either do a slight tire stretch or fender roll to clear, unless you want to put little more negative camber. If the size is more aggressive than ?x7.5 +42 or ?x7 +45(these are the optional and OEM width specs respectively) and the car is lowered most likely a tire stretch, fender roll, or some camber will resolve clearance issues.
