clutch problem?
Old Nov 8, 2010 | 01:32 PM
BigJohnXa's Avatar
Default clutch problem?
I have a hard time getting my 06 xA to go into first, third, and fifth and when i go to shift fast it feels like theres no second gear there any explanation clutch tranny clave cylinder anything would help
Old Nov 8, 2010 | 07:15 PM
my06tc's Avatar
how many miles are on the car
Old Nov 8, 2010 | 10:12 PM
BigJohnXa's Avatar
about 81000
Old Nov 9, 2010 | 12:35 AM
my06tc's Avatar
Originally Posted by BigJohnXa
about 81000
have to check out the transmission fluid,has it been changed
Old Nov 9, 2010 | 01:01 AM
BigJohnXa's Avatar
probably not ive had it since 57000 so ill look into that and maybe get it changed
Old Nov 9, 2010 | 11:14 AM
my06tc's Avatar
yea,cause i knew on my tc,when i was using stock tranny fluid,even though i had the clutch fully engage it was very hard to get into gears and what not,i thought maybe it was the clutch,but someone mention change the tranny fluid to aftermarket of your choice,and should be alot easier going into gears...
if your clutch was bad,people say,youll know it....there will be slipping and stuff..
But yea either check or change the tranny fluid....
Old Nov 9, 2010 | 01:43 PM
Sciond's Avatar
upgrade to synthetics it usually cure a notchy shifter
Old Nov 11, 2010 | 03:15 AM
BigJohnXa's Avatar
i think its my shift cable got melted so if yo can help me find one id appreciate it
Old Nov 11, 2010 | 09:45 PM
IH8ONYU's Avatar
the cables are thick metal rods, not wire
Old Nov 11, 2010 | 09:49 PM
IH8ONYU's Avatar
now, it is very possible (has happened to me) that your shift "cables" came out of their seats, under the console.. if you pull out the console, above the shifter, you will see 2 seats where the cables go from the shifter up through the cab and down to the tranny. mine had popped out, due to furious shifting when some somma_____ cut me off...
Long story short, for 2 days i was wondering why i had soooo much play in the shifts, but intermittent engagement.. pulled the console out, saw the problem, pushed them back down into their seats, and sprayed some lithium grease in the sleeves, and have been good to go ever since
hope this helps
Old Nov 11, 2010 | 11:18 PM
RedneckwithanxB's Avatar
Redline MT90 is your friend
Old Nov 12, 2010 | 02:39 AM
BigJohnXa's Avatar
well the cable under the hood by the header started ripping and i already checked the console shift cables
Old Nov 12, 2010 | 03:18 PM
IH8ONYU's Avatar
ohh, thats not good
Old Nov 12, 2010 | 11:10 PM
johnny_vitz's Avatar
When I put on my header I had to use some cable ties to hold the shift cables away from it. It's because most headers delete the OEM heat shield. Guess you'll need a new cable
Old Nov 13, 2010 | 06:19 PM
BigJohnXa's Avatar
yeah im looking for one right now but for some reason i doubt thats the problem cause i put the stock header on and zip tied it away and it was like that before and it shifted fine i think it may still be the clutch
Dmmcclair
Aug 13, 2015 07:14 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
yhwhdesign
10
Feb 6, 2015 05:00 AM
baker08tc
Dec 30, 2014 12:02 AM
tC4me
Feb 5, 2004 02:30 PM
