2004-2006.5 [NCP61]
xA rear interior creaking
Old Mar 8, 2005 | 12:32 AM
dougb's Avatar
Default xA rear interior creaking
I have a "creaking" noise coming from the left rear of the interior someplace, mostly when in left hand corners, or going up a slightly steep, slightly uneven part of the driveway.
Has anyone experienced this, and found a fix?
Old Mar 8, 2005 | 12:37 AM
M-Flo's Avatar
Try removing your tonneau (cargo) cover in the back and drive around. It you don't hear any squeaks then it might be the metal area that's bending under cornering.
The one in my car makes that sound. I plan to see my dealer to see if I can get it replaced.
Old Mar 8, 2005 | 01:08 AM
Ashe_WCM's Avatar
DeepSouth Scions
My cargo cover broke... I am going to find out if its under warrenty
Old Mar 8, 2005 | 02:10 AM
hnefrdo's Avatar
do you drive with one or both the rear seats folded down? i found my xa to have the same problem a while ago, and the sounds went away when i put the rear seats back up. the seats must reinforce the frame of the car or sumthing..
Old Mar 8, 2005 | 01:19 PM
jeffguynyc's Avatar
ashe,
Samething happen to my cargo cover. It is under warranty. However, I had to wait a week for it to come in. When I asked if I could just pick it up when it arrives and install it myself, they said no. Be prepared to make two trips to the service center.
Old Mar 8, 2005 | 01:34 PM
matt_a's Avatar
Originally Posted by jeffguynyc
ashe,
I was just going to say it dang-well better be covered! Bumper to bumper means just that. For the first 3 years or 36,000 miles, even your ashtray is under warranty (as long as you don't break it yourself )
Old Mar 8, 2005 | 01:44 PM
dougb's Avatar
Default creaking
haven't checked if the noise happens without the cargo cover, but it doesn't happen is someone (a light teenager) is sitting in the back seat so that affects the structure somehow. btw, it sounds like plastic creaking, not metal. It also happens with the back seats in the upright position - I guess I could see if it happens when they are folded down.
The dealer told me it was the seatbelts not being in the little clip holders on either side of the rear seats, but of course that's not it.
I was going to bring it back to the dealer to fix it, but I wanted to see if it was a common problem that's already been solved, and then I could tell the dealer what to do.
Old Mar 11, 2005 | 04:46 PM
dougb's Avatar
Default back seat creaking
turns out that the creaking noise happens in the right rear only when the right rear seat back (wider one) is in upright position... anyone fix that problem?
Old Mar 12, 2005 | 07:52 PM
XaRS0888's Avatar
had the same problem, took off the cover and everything is cool now.
Old Mar 12, 2005 | 08:53 PM
dougb's Avatar
tried that - took off the rear cover and it still happens - it only goes away when the right rear seatback is folded down...
Ferretgrrl
Oct 15, 2018 02:50 AM
airmankevin1
Feb 14, 2018 01:23 PM
sciontcguy15912
Mar 21, 2015 03:58 AM
CPL_Radar
Mar 5, 2015 05:42 AM
MosFed
Dec 27, 2014 03:24 PM
