Need to tighten Serpentine Belt
Old Nov 28, 2010 | 08:36 PM
cpuslave's Avatar
Default Need to tighten Serpentine Belt
Pronounced squealing noise getting worse over the past 2 months. A few searches haven't yielded any results... I imagine it's just a tensioner bolt to tighten, but I don't want to screw anything up. Any tips, suggestions, or procedures?
Old Nov 28, 2010 | 08:51 PM
N0AuTHoRiTy's Avatar
Check your belt to see if it's starting to crack, you probably have to change the serpentine belt. You can't adjust the serpentine belt on a tC, the tensioner pulley is self-adjusting.
Old Nov 28, 2010 | 11:01 PM
sw09's Avatar
There is no adjustment on the tensioner. Check your belt and see if its really worn down or cracked. Also see if your belt is loose, you should only be able to push it a little.
Old Nov 29, 2010 | 01:35 AM
thendawg's Avatar
The tc uses a hydrualic tensioner, so theres no adjusting. Try checking the ribs on the belt and insure theres no cracking, etc. ALso check the belt tenson by seeing if you can twist it. You can also try pullling on the tensioner (like you would to relieve tension to take off the built) - if its easy to turn, than the hydraulic part on the tensioner may have failed, and it will need to be replaced.
Old Nov 29, 2010 | 03:08 AM
cpuslave's Avatar
So if the serpentine belt is showing any wear/cracks and needs to be replaced, would I follow steps 1-3, 7, 26-29 listed here:
https://www.scionlife.com/forums/sho...erpentine+belt
Old Nov 29, 2010 | 03:26 AM
RoboCop's Avatar
^Yep. It's not too hard to replace the belt. The worst part is getting the new belt on. I broke my ratchet on the tensioner bolt when I had the belt halfway on. I just barely let the engine crank until it was fully on the pulleys. Probably not the best thing for the belt, but I needed to get it on.
rvascion
Nov 12, 2020 03:23 AM
olyellr
Sep 28, 2015 10:32 PM
Ksn
Sep 21, 2015 06:21 PM
antayala
Sep 4, 2015 05:12 PM
bmxScion
Jul 23, 2015 12:07 AM
