2008-2010 [ZSP110]
Fuel System Cleaner
Old Dec 10, 2010 | 02:20 PM
Palomino0513's Avatar
Red face Fuel System Cleaner
Hello all, here's a question, don't judge me!
When would you know that you need to use a fuel system cleaner on your car?
How exactly do you use it/ when do you use it?
I hear things like before long trips before you fill up tank, every other fill up?
How much to use on the car and what kind would you recommend?
Thank you!
Old Dec 10, 2010 | 03:30 PM
Julian_xD's Avatar
Redline products
Old Dec 10, 2010 | 05:16 PM
my06tc's Avatar
how many miles on the car
Old Dec 10, 2010 | 05:24 PM
SquallLHeart's Avatar
when would you know? you don't really...
you just make up a routine... perhaps on how many miles you've driven.. make it up.. and use whatever products you want.. though i'd stay away from the STP stuff. do a little research and search a bit.. people discussed about these things many times before.
I think for the most part, i haven't seen anything bad, and have heard that the Chevron Techron stuff works really well. Follow the directions on the bottle.
Old Dec 10, 2010 | 05:37 PM
CXTKRS1's Avatar
First off majority of the people who own vehicles never run an ounce of cleaner through them and never have any problems with said vehicle. If you still want to run a cleaner through the car then I recommend RedLine SL-1 and use say roughly every 25000 miles.
Old Dec 10, 2010 | 05:53 PM
also... as long as you run top tier fuel and not the crappy stuff... you shouldn't really need to use cleaners and additives.
Old Dec 12, 2010 | 12:51 PM
mikem53's Avatar
there are two types of FI cleaner. One is solvent based which can be hard on certain gaskets and diaphragms in the fuel system. These are very effective but should be used sparingly. The other is detergent based such as Redline and Lucas. These can be used often and won't deteriorate sensitive components in the system. The detergent based products work very well especially when used on a regular basis..
Solvent based products should be used as close to an oil change as possible since they do get mixed some with the oil thru the combustion process.
I use redline FI cleaner a couple of times a year.
Old Dec 12, 2010 | 02:08 PM
Sciond's Avatar
i always have luck with Seafoam too..especially once things get a bit more clogged
Old Dec 14, 2010 | 02:37 PM
cbmikey's Avatar
+1 on Seafoam. It's good for fuel and oil system cleaning. Good stuff!
Old Dec 16, 2010 | 04:33 PM
CXTKRS1's Avatar
Seafoam is an excellent product. Their is a similar product out called B-12 made by Chemtool, it is to be used with caution however since it is so harsh.
RY_TC07
Jul 18, 2017 05:18 PM
nightfox915
Apr 17, 2015 07:06 PM
carid
Mar 30, 2015 07:08 AM
spawnconnery
Dec 18, 2014 08:38 PM
eric_m
79
Mar 17, 2013 12:21 AM
