short shift install?? anyone
Old Dec 16, 2010 | 05:16 AM
doubleAs828's Avatar
Default short shift install?? anyone
how u install a short shifter ?? let me kno plz A.S.A.P
Old Dec 16, 2010 | 05:27 AM
GammaTNT's Avatar
https://www.scionlife.com/forums/tc-tech-diy-1818/short-shifter-install-twm-13582/
Old Dec 16, 2010 | 05:28 AM
Joyride's Avatar
Okay ill help you out.
First you unscrew the stock shift ****.
Then you se one of these
Once you cut it to a desired height you use some old fashioned white elmers glue.
it looks like that incase you cant find it in the store.
Once you have the glue you then glue back the ****.
learn how to search.
Old Dec 16, 2010 | 05:32 AM
ty but will the same steps will work for the 2010tc? cuz the model hasnt changed lol
Old Dec 16, 2010 | 05:34 AM
dropzone's Avatar
Go with what Gamma posted. Did you get one new or used? It's nothing exactly difficult, time to install can be anything from 30 to 1hr+, it's all on how familiar you're with cars, and don't work at night lol.
The install is the same from 2005-2010, no changes.
Old Dec 16, 2010 | 05:39 AM
its new i jus order it i think two days ago i ama try to put it next week this wont ____ up the warranty??, and also if i got to take apart like the arm rest the lighter?
-_-
Old Dec 16, 2010 | 05:47 AM
Spicy_McHaggiz's Avatar
Holy crap dude, SEARCH. All of your questions have been answered at least 100 times.
No, you don't take apart the armrest.
No, you won't void you warranty. A warranty is only void if the aftermarket part is the cause of the warranty claim. So don't mess it up.
Old Dec 16, 2010 | 05:51 AM
crush02342002's Avatar
one of the best diy's...as for the "black keeper" (I forget what its called exactly) I was able to lightly tap on the rod with a small hammer (pliers may work too). rod will slide one way and the keeper will fall off.
Old Dec 16, 2010 | 04:57 PM
MooSE55's Avatar
I took the arm rest and everything out..was a super easy install..hardest part is the "washer" with the reverse teeth..i actually just cut it out..probably the easiest way if you have a dremmel bc your new one should have a new one..
Old Dec 16, 2010 | 05:21 PM
^^ this
most all do unless you get a used one from someone.
NonStopTuning
Jun 29, 2015 07:42 PM
Frustratez
Feb 26, 2015 04:03 PM
disaster06
Dec 26, 2014 03:00 PM
disaster06
Dec 4, 2014 07:05 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
