Rear suspension is squeaking?
Old Dec 17, 2010 | 03:19 PM
serith's Avatar
Default Rear suspension is squeaking?
Just the other day this started to happen. It's most noticeable when going slower over bumps in the road. When the back end is going up and down because of the ____ty roads around here, i hear this annoying squeaking sound. I have tried to manually reproduce this sound by bouncing the back-end of the car up and down, but nothing. Could it just be because of the colder temperatures we're experiencing right now? It's just annoying, and I don't remember this happening last winter. The car only has 16xxx miles. Probably going to bring it in, it's just a PITA.
Old Dec 17, 2010 | 04:27 PM
my06tc's Avatar
i have the same issue,i only started to noticed it,when it started to get really cold out,i do have lowering springs,but didnt have them long enough to have the shocks go out
Old Dec 17, 2010 | 04:44 PM
feldy's Avatar
Yep my rs5 does it to. I know a lot of the peeps had to take there car in due to the sway bar. I took my in over the weekend and it was the sway bar bushing it was broke. However yesterday my car is still making that same noise your talking about. When there are two people in the car it does not happen. I think becasue the back end can not fully compress back to its full upright position. mine only has 10k on it.
Old Dec 17, 2010 | 05:07 PM
serith's Avatar
I don't think it's the sway bar, I've looked under the car and it looks intact. I've had another adult in the car and the noise still persisted. I don't think it would be the shocks if I've only driven the car for 16k miles. There has to be something that we can do to fix this though, short of taking it to the dealership. It's just a huge inconvenience to bring it there, but I guess I should while I still have the warranty.
Old Dec 17, 2010 | 05:20 PM
serith's Avatar
so after doing some research online, it looks like it's either the sway bar bushing, or the struts have gone bad. i'm making a service appointment right now.
Old Dec 17, 2010 | 05:58 PM
SilverCFtC's Avatar
Mine does this, only when cold. It is the sway bar bushings, I have a TRD rear sway with polyurethane bushings so when cold they squeak, not sure why a stock sway would do that, a little lube should clear it right up. A blown strut should be noticeable when going over bumps.
-Sean
Old Dec 17, 2010 | 06:06 PM
serith's Avatar
i just scheduled an appointment to be safe, but the tech said that it might be dirt/sand from the road that is caught, and causing it to squeak. i'm not sure if i buy that or not, but i'm hoping it's that or just because it's cold out. i just have a really hard time believing that it's mechanical failure at 16k
Old Dec 17, 2010 | 06:10 PM
serith's Avatar
-Sean
i also have the trd rear sway, unsure what bushings were used though. this makes me feel a little better knowing that i'm not the only one at least.
Old Dec 17, 2010 | 06:25 PM
pwee08's Avatar
Same issue is happening to mine but i have 50k on my motor. I think my struts are going back only the rear tho kinda sucks. I dont think it would be my rear sway bar since its OEM. But how do i check if it is? Do i look for something crack around the sway bar? see if the rubber bushing is breaking?
Old Dec 17, 2010 | 07:18 PM
SilverCFtC's Avatar
Step one, bounce your car in the driveway, where does it sound like the squeaking is coming from? The bushings on the sway bar are pretty far inboard, so if you can't isolate a side I'd check them next. Easiest way to do that, put the rear on jackstands, disconnect the endlinks, and rotate the sway bar. If you get nothing, re-connect everything, and take it to a suspension shop and have them look at it.
Or just turn the radio up for the winter (which is what I do) :D
-Sean
Old Dec 17, 2010 | 07:20 PM
SilverCFtC's Avatar
Yeah I've got Energy Suspension bushings. Not sure how TRD shipped the things, got mine lightly used (display) and had to get the bushings separately.
-Sean
Old Dec 17, 2010 | 08:01 PM
pwee08's Avatar
Its only coming from the driver side so id check there first and see how it looks.
Old Dec 18, 2010 | 12:30 AM
landark's Avatar
I had this problem with my 2005 with TRD springs. I never really figured out what the problem was. It was only on the driver's side and only made noise while going slow over speed bumps and such. I always figured it was that the spring wasn't seated properly - but I also put on a TRD sway the same time as the springs. No noise while I was stock.
...I guess this didn't really help at all.
Old Dec 18, 2010 | 12:41 AM
my06tc's Avatar
i got the trd sway bar also,but it wouldnt make sense if thats it causing it,your going over speed bumps and thats the job of the shocks or struts,but then again,i could be wrong,but i have about 61k on my 06........and as soon as it got really cold out like high 20's o lower 30's..ive noticed the noise.....guess ill check out my sway bar along with my shocks...
Old Dec 21, 2010 | 01:19 PM
Blk5speed07's Avatar
Yeah my rs5.0 does the same thing.
Old Jan 7, 2011 | 03:39 PM
feldy's Avatar
Any news on what the cause is?
Old Jan 7, 2011 | 05:28 PM
serith's Avatar
I just dropped the car off this morning, and they called me an hour ago and told me that it is indeed the sway bar bushings. He said that the tech took the sway bar off, greased up the bushings and put it back on, but the noise is still there, just not as bad. They are ordering a new kit that will replace the bad parts for me, and it should be here next week. I just wonder even if this does work, how long will it be squeak-free until it happens again? >.>
Old Jan 7, 2011 | 07:55 PM
feldy's Avatar
my bushing was broke also got replaced and still making the same noise as before. im going to wait for it to warm up a little and see if it goes away.
Old Jan 9, 2011 | 01:43 PM
serith's Avatar
this is the receipt i got from the dealer for this problem:
#1 - Customer Reports:
CUSTOMER STATES VEHICLE IS MAKING A SQUEAKING
NOISE WHEN SLOWLY MOVING FROM THE REAR OVER BUMPS. DIAG &
ADVISE.
Caused by
C: SQUEAKING NOISE COMING FROM THE REAR OVER BUMPS
C: FOUND REAR SWAY BAR BUSHINGS CAUSING NOISE.
REMOVED REAR SWAY BAR BRACKETS & BUSHING,
LUBRICATED THE BUSHINGS & INSIDE OF BRACKETS.
REINSTALLED REAR BUSHINGS & BRACKETS. NOISE 75 %
BETTER.
Corrected by482991: (91) (55)
Work performed by Travis Burr (64) 0. 70hrs
Unrealized PTR11-21052 :TRD TC SUSP BUSH&BR Qty: 1
OP CODE 482991 (0.7)
T1=91
T2=55
R: ORDERED NEW BUSHING KIT
WARRANTY WORK $0
I can't hear the noise anymore, but they're ordering me the new parts, which is great. That noise was god awful.
scotttie17522
Feb 23, 2020 08:38 AM
carid
Feb 12, 2015 11:54 AM
toyotaisme
Jan 10, 2015 10:24 PM
fluxingnation
Dec 26, 2014 04:28 PM
TwisTeD_ScioN
10
Sep 22, 2004 09:32 PM
