2011-____ [ANT20]
A/C and Recirculation Air button
Old Feb 16, 2011 | 05:47 AM
Tc2ndGenWhite's Avatar
Default A/C and Recirculation Air button
Where did the button go to select outside air as your air source thru your vents???
I see the selection for recirculation.....but that's only good if your using A/C!
What gives???? Am I missing something?......need to look in the owners manual maybe!!!
Old Feb 16, 2011 | 06:29 AM
XerotC's Avatar
if that button is off its getting air from outside, if that button is on that means its recirculating.
Old Feb 16, 2011 | 12:14 PM
MykeJ's Avatar
I think its in the middle of the air control but i could be wrong Ian not in the car right now. Its just like the button for the rear defroster.
Old Feb 16, 2011 | 02:39 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
button on left **** (selecting the air vent ****)...if the light is one then its recirculation, if its off then the vent is open to outside air
..try this, if u have the (front) defroster on the air needs to be open to the outside.
So if you have the recirculation button on (light on) with the **** on anywhere without the defroster sign, then turn the **** to either of the defrosters...the button will automatically pop and turn off the recirculation
Old Feb 16, 2011 | 02:43 PM
Thanks! I appreciate it.
Old Feb 16, 2011 | 05:08 PM
Syldrin's Avatar
speaking of missing items i was sitting in a 2011 the other day and i didnt see the engine temp gauge is there not one?
Old Feb 16, 2011 | 05:15 PM
mdiluxe's Avatar
^No!
Old Feb 16, 2011 | 08:23 PM
VVTinme's Avatar
There are lights that come on if the temperature is cold or too hot.
Old Mar 15, 2011 | 03:35 PM
cement's Avatar
better in my opinion. less clutter on the cluster!!!! lmao...
Old Mar 15, 2011 | 05:48 PM
Bloodborn's Avatar
If the recirc is off it works for AC and heat...____ will run you out of the car if your on a trip and leave the heat off but turned to warm air instead of in the middle.
hydrogen
Jul 14, 2020 09:41 PM
ShawnMcc
Jul 11, 2015 11:07 PM
ScionXa06
May 18, 2015 10:05 PM
randompacking
Jan 28, 2015 11:43 AM
DerekMarq
Jan 27, 2015 02:38 PM
