Jerking during acceleration
Old Feb 24, 2011 | 08:10 PM
ChvyKc's Avatar
Default Jerking during acceleration
The car is bone stock and has 57,000 miles on it. Manual.
It does not do this at full throttle. Basically when I let the car rev up at half throttle the car will jerk through the middle rpm range and then run fine above 4500-5000 rpms. I first noticed it trying to gain speed going up a hill after a redlight. It doesn't do it every time and its always a different severity. It's been happening for almost a year now.
I've taken it to the dealership twice and of course it stops doing it as soon as the tech gets in the car. I did finally get a good datalog on the car today. The only thing that I see is the short term fuel trim jumping everywhere. I know its suppose to be constantly correcting buts its all I see that's weird.
Throttle/RPM/STFT
23.52/2372.5/3.90625
34.90/2629.5/4.6875
51.37/2925.0/-3.125
56.47/3235.0/2.34375
56.47/3560.7/-0.78125
56.47/3893.7/6.25
56.07/4203.7/-0.78125
56.07/4507.0/-4.6875
56.86/4844.5/-10.9375
56.86/5164.7/0.0000
56.47/5482.0/0.0000
56.86/5795.2/0.0000
56.86/6087.5/0.0000
It seems like once the STFT goes to 0 the car runs great. The two data passes with STFT at -4.6875 and -10.9375 both have the same exact vehicle speed so the car had a pretty hard jerk right here before reving the rest of thew way without a problem. The jerks always get worse the longer you rev with the worst one being the last. The car hesitates a little, then jerks a little, then jerks pretty hard and then revs all the way to redline without jerking again.
I really need some help guys. This is driving me crazy. If you need any more information or would like to see a different log just let me know. My datalogger should pull whatever you need. Thanks in advance.
Old Feb 24, 2011 | 09:43 PM
emrules2001's Avatar
Clean your MAF and injectors?
Old Feb 25, 2011 | 12:52 AM
ChvyKc's Avatar
I've cleaned the MAS (with MAS specific clearner) and run injector cleaner through the car a couple of times. Maybe a bad MAS or a bad O2?
MAS readings on the pull above went from 1.99 to 15.50 smoothly. I did not log the O2 sensor but I can.
Old Feb 26, 2011 | 12:29 AM
ESEMRFOZZ13's Avatar
my cadi did this when it got a fine crack on the sparkplug. just a thought.
Old Feb 26, 2011 | 12:53 AM
mmmpshh's Avatar
injector/coil/fuel injector?
Old Feb 26, 2011 | 03:46 AM
x_Batman_x's Avatar
yeah I would go for changing the sparkplugs before anything else.
If not that then maybe a fuel pump issue. Have you noticed a significant change in fuel economy?
Blunderbuss
Oct 8, 2015 04:56 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
Brently1
Aug 12, 2015 10:54 PM
mc1114
Aug 12, 2015 02:07 AM
RokGoblin
Aug 11, 2015 02:45 PM
