SASCA SCCA 3/13/05 (San Antonio Sports Car Association)
Old Mar 14, 2005 | 03:39 AM
DGTLLVR's Avatar
Default SASCA SCCA 3/13/05 (San Antonio Sports Car Association)
57.342 best time... I only ran three laps, didn't go for the second set because i have this weird noise coming from my CV joint on the drivers side. I was running with the bad boy Civics and Proteges timewise. With rear sway bar removed I think I could have bested most of them, with the excepton of the full race prep cars.
Workers at the first corner radioed DNF all three laps, although no one else that was there saw me miss anything. The cone they pointed out was one I clearly remember sliding right past (go go gadget understeer). Roadbuster was working in the trailer and didn't see it, the last time they radioed in a DNF on me from the first corner, my lap was over.
So I don't get what was going on with it, and I'm going to wait to see what they post on the site before I contest it. I made it through with no cones killed and only one moved slightly inside it's box in the slalom. I started at 58.8xx, second lap was 57.9xx, and ended my day with the 5.7342
If I do get one run that isn't DNF, it'll give me my second FSP class win in two events.
Rear sway bar is coming out next time damnit.
Mad Tyte JDM Props to Cameron for taking the pics of me ballin outta control in the toaster.
Old Mar 14, 2005 | 05:48 AM
heme11's Avatar
what do you have in your car suspension wise?
Old Mar 14, 2005 | 10:38 PM
TXboxdriver's Avatar
yeah, i heard you were talking mad $h1t to everyone there before you ran
but good effort, man
Old Mar 14, 2005 | 11:40 PM
DGTLLVR's Avatar
Tanabe DF210 Springs, DC Sports Strut bar, Hotchkis Sway bars, One Ton garage rear spacers... and the big rims, thats about it.
I have the Injen Short ram, that keeps wheels spinning coming out of corners. I really need to get a LSD if I wanna go faster.
Old Mar 14, 2005 | 11:41 PM
DGTLLVR's Avatar
I talk junk to everyone all the time But then I backed it up with decent enough times. I just wish I could have ran my second set of three... I could have dropped the rear sway and maybe gotten it to come around easier.
Old Mar 15, 2005 | 12:25 AM
heme11's Avatar
thanks!
Old Mar 18, 2005 | 02:38 AM
dinkjs's Avatar
you would probably of been faster if you werent running such large rims
Old Mar 20, 2005 | 06:15 PM
DGTLLVR's Avatar
Actually I've run on 17's and 18's The sidewall issue doesn't seem to be coming up at all. I actually run faster times on my 19's. My main issue on a SCCA Solo course is removing my rear sway bar... (i forgot to remove it this time.. DOH) On road courses and daily driving, having the rear sway bar in there is nice, but when it's out I can rotate the car alot easier.
Oh, and I could use a freakin LSD... If anyone knows of a good company making an LSD for these crap transmissions, please post and let me know. I really really need one. Spinning a tire all the way around the track with 92whp is just retarded.
Old Mar 21, 2005 | 07:53 PM
hotbox05's Avatar
Why would you remove the rear sway? do you like understeer?
Old Mar 23, 2005 | 07:03 AM
DGTLLVR's Avatar
No, the rear sway bar causes understeer. It keeps too much traction on the rear tires. Removing it allows the rear to break loose in low speed, tight turns. Which would have caused enough oversteer that I could have gotten around the cones and started applying more power to the ground sooner. With the rear sway bar in place, all my car did was understeer, and it cost me a ton of time.
Old Apr 4, 2005 | 05:31 AM
BeQuietAndDrive's Avatar
Erm...well,I don't have any personal experience, but, that goes against everything I've ever read.
Old Apr 4, 2005 | 05:32 PM
when choosing which lack of traction to use
(over or under-steer)
one also needs to realize that oversteer is only desireable when you can control it with the pedal, it is too easy to get way too far out in an FF car-with no way to recover
understeer is less than desireable because it is relatively uncontrollable, but in an FF you can Left foot brake and make up some better traction
unless you are at the level where you are comfy "un-steering" to get traction back
long story short
oversteer ain't reliable,controllable or desireable in an FF
a$$-dragger!
and adjust your line to take advantage of the "push"
minter66
Dec 15, 2014 01:45 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
eric_m
79
Mar 17, 2013 12:21 AM
Risen_Son_Racing
May 6, 2005 02:31 PM
tC_Normo
Oct 22, 2003 07:20 PM
