Scion tC 2G ICE & Interior In-car entertainment and electronics...
Remote cable/ Amp Turn On Need advice
Old Apr 11, 2011 | 03:16 PM
w11tc's Avatar
Default Remote cable/ Amp Turn On Need advice
I'm going to be installing my subs today to the stock Pioneer head unit.
I want to get everyones opinion about how you are connecting the rem/amp turn on cable to the stock harness that goes into the head unit.
Old Apr 12, 2011 | 12:42 AM
deaddawg's Avatar
Quite a few amps have the ability to automatically turn on and off based on input from the RCA inputs. You may want to start there.
Old Apr 12, 2011 | 05:07 AM
w11tc's Avatar
I'll give it a try!
Thanks!
Old Apr 24, 2011 | 06:12 PM
BeloZero's Avatar
there are a couple ways to do that, if you have a knock-out available, you can use any 2 position toggle switch and turn your amps on/off that way. or you can splice your remote wire into the red wire on the harness (i think its red, i havent removed the radio in the new tc yet) you can test it by checking for voltage with the car off, then check it again after you start it, if you get your ~12VDC after its running, then splice into it. EDIT: i installed my amps and subs and used a splicing clip into the red wire on the back of the radio harness. works perfect.
TheSilencerTC
Feb 24, 2015 04:56 PM
setpol
Feb 17, 2015 11:33 PM
toyotaisme
Jan 10, 2015 10:24 PM
TJ
Nov 6, 2003 01:16 AM
vpkb
12
Oct 8, 2003 04:17 AM
