Offset for 2011 tC
Old May 5, 2011 | 11:23 PM
Fearz's Avatar
Default Offset for 2011 tC
I just got a new tC. Its black and i wanted to know the best offset for wheels. Really like Rota grids (they may be played out to some) but i like the look.
I want to know what offset would get me right inside the fender so if i wanted to drop my tC later it would look sick. Sorry this is my first post i didn't see a noob section or maybe i didn't look hard enough.
Anyway thanks for the help.
Old May 6, 2011 | 12:04 AM
fmtrdtc08's Avatar
18x9.5 with 30 offset or less
Old May 6, 2011 | 01:42 AM
Fearz's Avatar
I found the rotas in +38 and +20. I would think the 38's would be good if not I could use a spacer. Or if anyone knows if the 20's would be perfect I would get those. I'm talking 18x9.5 here. Or would it be cool to go 18x10 in the back and 18x9.5 in the front or would that be to much work? Keep in mind I'm a college student but the only thing I see being a problem is tire cost.
Old May 6, 2011 | 01:48 AM
1stOne's Avatar
I'm biased, but I don't like staggered wheels on a FWD car.
I'm running 18x9.5" with a +45 now and it works, but I've ordered 3mm spacers to help.
You should be perfect with +38. THe +20 will hang out the side and look stupid.
Old May 6, 2011 | 02:37 AM
Fearz's Avatar
Do you have a pic of your 45's
Old May 7, 2011 | 12:49 AM
Fearz's Avatar
Super noob question. The tc2 bolt pattern is 5x114 right? I believe it is but I'm ordering and they have 5x100 and 5x114.
Old May 7, 2011 | 01:00 AM
kahsperr's Avatar
19x8 in the front et35 - 225/35/19
19x9.5 in the back et35 - 255/30/19
Old May 7, 2011 | 02:00 AM
Fearz's Avatar
^ How flush are those I want right inside the wheel well? Anyway they look good and still with the sticker in the in the window.lol
Also the lug is 5x114.3 right?
Old May 7, 2011 | 02:19 AM
1stOne's Avatar
Hate to say it so early, but search is your friend (not to mention there is a link in my signature).
https://www.scionlife.com/forums/sho...d.php?t=194394
That will depend on tire size, suspension setup, alignment settings, etc. What works for one person should be used as a guideline for others, not gospel.
For example, my tires are a lot wider than what kahsperr is running. Although we both have 255's on (I have them on the front as well), we are running a different type of tire which will change the stance of them. Track type tires naturally sit wider than street tires.
But yes, the pattern is 5x114.3mm.
Old May 7, 2011 | 02:57 AM
Fearz's Avatar
^ My bad I had looked at your thread but I didn't edit my post. I figure I'll just order and see what happens.
Old May 7, 2011 | 06:09 PM
kahsperr's Avatar
tC1.jpg?t=1304718165
The rear wheels sit perfectly. I would have chosen a 32 or 30 offset in the front instead of a 35 if I could do it over again.
Old May 7, 2011 | 08:19 PM
Fearz's Avatar
^ the back perfect. So I think the +38's will be fine if not I put spacers.
Old Apr 18, 2016 | 07:51 PM
jcraff3's Avatar
Default Wheel fit check
I'm about to order 18x9.5 +15 aka 1 inch. Any positive offset pushes away from the center so I should be set right? It will bring me away from the hub, 1 inch / +15 (15mm)
Old Apr 19, 2016 | 03:10 PM
tC_toph's Avatar
Ive seen this on club tc so i figured i should post it here too... you could probably get away with a few mm difference than this chart but anything drastically different will most likely rub.
Old Apr 19, 2016 | 06:18 PM
jcraff3's Avatar
That's a geb1 wheel fitment guide the gen2 one sucka and i's not detailed enough at all to understand. But I did the math and found out what I need
Old Apr 19, 2016 | 06:35 PM
tC_toph's Avatar
I agree the 2nd gen charts previously posted in other threads are pretty much useless. glad you figured out what you need, just wanted to catch you before you ordered some 9.5's w/ +15 offset, that would stick out like crazy.
what did you decide on?
I got 19x8.5 w/ +35(i think), wish i woulda gone +30.. Although its very close to that maximum flush without rub look
richard_rsp
Apr 6, 2017 09:37 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
Pkdust
Oct 20, 2015 04:27 PM
terrye
Sep 26, 2015 12:24 AM
