Car starting Problem *help*
Old May 22, 2011 | 12:27 AM
Xx AzN xX's Avatar
Default Car starting Problem *help*
ok so i have 07 Scion tC 5spd with 97,XXX Miles. So my problem is that my car wont start when i have the clutch all the way down. (its almost like trying to start the car without the clutch down) It will eventually work after i release the clutch and try again. This dose not happen every single time i try to start the car only once a while. please help.
also, i recently replaced my battery and my mods are intake and exhaust.
Thanks
Old May 22, 2011 | 01:56 AM
sciontc_mich's Avatar
check your clutch interlock switch. it's required to start the car, might be bad or just needing to be adjusted into place.
Old May 22, 2011 | 05:04 AM
Xx AzN xX's Avatar
where do i go to find this?
Old May 22, 2011 | 10:07 AM
helloninja's Avatar
It sits under the clutch pedal, on the floor. When the clutch is pressed it should press the switch to allow you to start the car.
Old May 22, 2011 | 03:19 PM
Xx AzN xX's Avatar
oh ok thnx ill check that
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
BV19869
Dec 11, 2014 06:05 PM
