clutch pedal problem
Old Jun 9, 2011 | 11:42 PM
malrki42's Avatar
Default clutch pedal problem
i upgraded to the act street disc with the xtreme pressure plate. the clutch wouldnt disengage so got the different extended pushrod and tht didnt disengage the clutch so we adjusted the clutch pedal now the clutch disngages fully only problem is the pedal has to b less then an inch from the floor almost all the way on it i was wondering if anyone knew of a different bolt for the pedal to help get it away from the wall?
Old Jun 10, 2011 | 12:24 AM
my06tc's Avatar
refer to this thread
https://www.scionlife.com/forums/sho...d.php?t=183608
but you will need to ajust the push rod inside the cabin behind the clutch...
Old Jun 26, 2011 | 03:30 PM
loroku's Avatar
im the op's tuner/mechanic we still cannot get the clutch to be right we installed the extended rod and adjusted out the master cyl rod all the way out and it stil is hard for the op to it disenguages at the bottom very very bottom of the pedal shift i think either the slave or the master cyl is bad or we have a bubble but im thnk the clutch line may be bad whata your suggestions guys
Old Jun 26, 2011 | 05:08 PM
rangerryda's Avatar
If full adjustments and proper bleeding don't fix the issue, that only leaves master cyl and slave cyl issues. Exedy stage 1 is perfect and held up my 285+ hp without a hint of slipping and is very drivable. Still chirps 3rd N/A lol.
Old Jun 26, 2011 | 05:26 PM
loroku's Avatar
ill give rebleeding a try then if it doesnt work im gonna try to replacing the cluch line as it has close to 130k miles on it is not that then lengthen the mater cyl rod.
Dmmcclair
Aug 13, 2015 07:14 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
Dapitt84
Mar 4, 2015 02:03 AM
greddy05tc
Feb 20, 2015 02:16 AM
baker08tc
Dec 30, 2014 12:02 AM
