Head bolts loose - symptoms?
Old Jun 15, 2011 | 09:13 PM
sciontc_mich's Avatar
Question Head bolts loose - symptoms?
I've read about the 2AZ-FE engine (our engine) and how the head bolts can loosen out of the block. Some have had to have their engines replaced because of it. Toyota even released a service bulletin about it.
My question is, what are the symptoms BEFORE the head bolts really separate from the block? What would we look for to happen?
Old Jun 15, 2011 | 09:17 PM
Gutling's Avatar
Oil leaking at the headgasket
Old Jun 17, 2011 | 06:34 PM
SandMPerformance's Avatar
it's not necessary a "loose bolts" problem. IMO the 2az water pumps are known to leak rather regularly, which causes higher engine temps from the lower coolant levels. with the higher engine temps the aluminum block has a problem where the threads in the block for the headbolts will become softer causing the headbolts to actually "pull the threads out of the block". Gutling is correct though, you will see either oil or coolant from a headgasket failure.
Old Jun 18, 2011 | 03:32 AM
thanks that makes sense of what I would see. I've also heard "weeping from the water pump weep hole" is the sign the water pump is dying, since the water pump looks like it plays a role in this overheating, is a water pump that is weeping from the weep hole about to die?
Old Jun 18, 2011 | 03:50 AM
tc-guy's Avatar
leakage from the weep hole is a sign that the waterpump is failing. when exactly it will totally fail isn't sure but that's the indication to change it before it totally fails and not pump the water through the engine at all. if that happens engine will overheat and most likely will have head gasket issues.
Old Jun 18, 2011 | 12:14 PM
it's rare that a water pump completely fails. I have heard of them leaking heavily where they will spray that pink "flaky" residue everywhere or where they will make a metalic rattling noise, and those have been the worst cases that I know. The weeping of the water pump is just the start of your leak and things don't get better after that.
Greg S
Jul 21, 2016 07:28 PM
mickkassem
May 12, 2015 03:36 AM
P944
Apr 30, 2015 06:04 PM
knepart
Scion FR-S Forced Induction
Apr 25, 2015 02:48 PM
Itsdchz
Jun 30, 2009 04:54 AM
