head gasket
Old Jun 20, 2011 | 06:11 AM
lee_tC's Avatar
Default head gasket
I need a new head gasket and was thinking about buying the one from dezod but it has a option of a 89mm bore or 90mm......the stock bore is 88.5mm so is it ok to get the 89mm?? or should i just go and get an OEM one?
http://www.dezod.com/pd_cometic_mult...sket-2azfe.cfm
Old Jun 20, 2011 | 12:11 PM
skinnayyy's Avatar
Team Scionara
get OEM from TRD sparks. i've heard some bad things about the cometic head gasket.
Old Jun 24, 2011 | 04:44 AM
BlackKnight's Avatar
Music City Scions
Reliable sources? Like what? I know several people with these without issues. Also who did the assembly of the engine? Its easy to blame a faulty components when you don't know 100% what you are doing even though you might think you do.
To me building an engine isn't assembling it. It involves machining the head, machining the crank, machining the sleeves and etc. Assembling the engine involves a lot of checking i.e. runout, tolerances, using plasti gauge and etc. Using new bolts instead of trying to be cheap and reusing head bolts (most not all head bolts are torque to yield meaning one time use and you will never gain the proper torque again). Properly assembling components using the correct torque and following the torque procedures.
yupinmytC
22
Jul 27, 2024 07:08 PM
prescottn
Oct 8, 2015 05:31 PM
olyellr
Sep 28, 2015 10:32 PM
MisterSkiz
Sep 27, 2015 10:25 PM
BlingSlade
Sep 5, 2015 08:52 AM
