head gasket
I need a new head gasket and was thinking about buying the one from dezod but it has a option of a 89mm bore or 90mm......the stock bore is 88.5mm so is it ok to get the 89mm?? or should i just go and get an OEM one?
http://www.dezod.com/pd_cometic_mult...sket-2azfe.cfm
To me building an engine isn't assembling it. It involves machining the head, machining the crank, machining the sleeves and etc. Assembling the engine involves a lot of checking i.e. runout, tolerances, using plasti gauge and etc. Using new bolts instead of trying to be cheap and reusing head bolts (most not all head bolts are torque to yield meaning one time use and you will never gain the proper torque again). Properly assembling components using the correct torque and following the torque procedures.
BlingSlade
Sep 5, 2015 08:52 AM
