Scion xB2: High Power LED Reverse Light version 2.0 [08-10]
Old Jun 20, 2011 | 10:42 PM
LEDmod's Avatar
Default Scion xB2: High Power LED Reverse Light version 2.0 [08-10]
Scion xB2 : High Power LED Reverse Light version 2.0 for 2008-2010
* Free shipping within US
  • Plug and play
  • Bright HID White
  • High power but uses1/5th of the stock bulb power
  • Low heat, will not burn or melt the stock socket
  • Very long-life
  • 1-year hassle free warranty (just return it and we'll send you replacement free of charge)
New Version 2.0
- Most powerful LED bulb with extreme reliability
- Multi-chip SMD technology for maximum brightness
- Large aluminum heat sink for long term use and extended reliability
* NOTE for 2011 and up model: Scion change the reverse lights on 2011 to two smaller bulb.
We are in the process of making another design to fit that model. (Coming Soon...)
Check out the prototype from here
- Direct link to the ordering page
Note : They are pure white in person, camera makes it look bluish
Untouched photo below (with ambiant lighting)
Old Jun 20, 2011 | 10:43 PM
LEDmod's Avatar
Old Jun 20, 2011 | 11:46 PM
NaughTC's Avatar
will it work on a 07+ tc?
Old Jun 21, 2011 | 01:03 AM
LEDmod's Avatar
Sorry tC uses different size socket.
Needs to modify to make them fit different size socket.
Old Jun 21, 2011 | 01:56 AM
Effortless's Avatar
hi Sean,
You didn't state how much these are going for?
thanks,
Daniel
Old Jun 21, 2011 | 01:59 AM
dshiznit's Avatar
site says 19.99
Old Jun 21, 2011 | 05:33 AM
flyingemu05's Avatar
i have the first version of the back up light, how much brighter is this that the old one?
Old Jun 21, 2011 | 08:27 PM
LEDmod's Avatar
Originally Posted by Effortless
hi Sean,
thanks,
Daniel
- Direct link to the ordering page [Same price, but improved designed]
Old Jun 21, 2011 | 08:28 PM
LEDmod's Avatar
It's about 30% brighter and improvement over reliability...
Old Jun 21, 2011 | 11:28 PM
masterbB's Avatar
will this cause the turn signals to hyper flash
Old Jun 21, 2011 | 11:31 PM
LEDmod's Avatar
This is for the reverse light.. not turn signal..
Old Jun 22, 2011 | 12:09 PM
11ScionXb's Avatar
Would there be a bulb that would fit the 921 I would like to put these in my '11 Xb
Old Jun 22, 2011 | 10:32 PM
LEDmod's Avatar
I have new LED bulbs, but not sure if it will be crazy bright..
Old Jun 25, 2011 | 07:14 AM
ScionFred's Avatar
What is the lumen rating for this bulb?
Old Jun 25, 2011 | 06:44 PM
wadles143's Avatar
I would love to get some for my reverse lights and if they can replace the wedge type bulb in the parking light socket in the headlights, I'd love to get 2 for the front as well. Hit me up if the specs match up and I'll be ordering straight away. Aloha!
Old Jun 27, 2011 | 09:55 PM
LEDmod's Avatar
What kind of specs do you need??
LEDmod's Avatar
Sorry don't have lumen rating on this...
You can't really decide the LED bulb from lumen rating, since most of the are inaccurate rating...
One of the main reason is that, LED bulbs usually have LED is multiple direction..
Also depends on the viewable angle of the LED will change the lumen rating completely...
Example with two LED that has same power output.. 30 degree will have mutiple times more lumen then 120 degree angle...
Old Jun 28, 2011 | 12:09 AM
wadles143's Avatar
I need at least 2 of a 168 (or 194 I think) wedge type bulb for my parking lights/license plate bulbs, 2 of 921 type for my reverse lights (the 2011 has reverse lights in each tail light instead of the single offset one in the bumper), and if those switching turn signal bulbs that you have will fit the turn signals for a 992 or 7440A bulb, then I would want two sets (4 total bulbs) to switch those. Please let me know. Thanks. Aloha!
Old Jun 28, 2011 | 06:29 PM
LEDmod's Avatar
168 has same socket as the 194, but with bigger bulb size...
You can use 194 bulbs, but most of them aren't as bright as the 7440 size
I do have some much bigger size LED then typical 194 LED...
For the license plate light, I sell four 4-chip LED which fits perfectly in the xB2 license plate housing... also the brightest for it's size....
You should consider getting dual color for the front turn signal..
http://store.ledmod.com/index.php?ma...products_id=72
Old Jun 28, 2011 | 08:14 PM
wadles143's Avatar
So the bulb depicted in this thread will not work in the reverse lights or the parking lights? Sorry, I'm a bit confused. If I ordered four of the bulbs that you pictured in the original post for this thread, would I be able to use them in the parking light and reverse light sockets? I also am a bit confused about how the turn signal lights would work. It says plug and play, but there is also mention of a relay. Would I just replace the OEM socket with the one you provide, or do I also need to wire in a relay to prevent the hyper flashing? Wiring the relay is not something I've done before, so I might be hesitant to mess with that. I've also been warned by several other guys that the turn signal lights should not be messed with (melting, hyper flash, dead lights after a short time). Any more help would be appreciated. I can also call the number if that is easier and talk to someone. I am in Hawaii, so let me know what time to call if so. If the bulbs work for the sockets I have, I would order 4 turn signals, 4 of the wedge type bulb in this thread, and 2 license plate lights as well. Thanks for your time. Aloha!
