ABS, Brake and Tire pressure (!) flashing..
06 tC, 96xxx miles, auto.
What could be the reason?
Was driving and randomly the lights came on, the (!) light is flashing...when i turn the car off, all the lights disappear, but comes back on in a day or so.
Checked multiple threads...and checked up the brake fluid level (which is fine), tire pressure is fine, what could be the culprit?
_______
_______
I would see if there are any trouble codes (Toyota calls them DTC, diagnostic trouble codes). Autozone can hook up a code reader.
I know on the 05-06's they measure the tire pressure by using the ABS sensors, the later years have transmitters mounted inside the wheels to measure the air pressure.
Could be a faulty ABS sensor/wiring. check to see if you have any codes first.
____
____
check to make sure all your ABS sensors are plugged in correctly and no wires are torn... i got the same lights a while back and it turned out that the ABS sensor wires on the right rear tire were torn...
kiss_kiss_kill
Jan 13, 2008 06:54 AM
mauiXaXbTc
Scion xB 2nd-Gen Wheel & Tire
11
Oct 24, 2007 01:20 PM
