In serious need of help with Tranmission
Old Jul 16, 2011 | 11:33 PM
orangeman25's Avatar
Default In serious need of help with Tranmission
I've just replace the clutch and flywheel, and i'm having a killer time putting the tranny back on. I'm using a tranny jack and for some reason I can't get it straight enough to stab it back to the engine. I still have the subframe installed I don't know if it would help to remove it. Anybody have any tips.
Old Jul 16, 2011 | 11:48 PM
VINC3TC1's Avatar
Stop, grab a beer relax go back and look at it again with a fresh mind.
Old Jul 17, 2011 | 12:23 AM
chicotunner07's Avatar
make sure all the guide pins are in the right place, also, having a second pair of hands always helps, and make sure the clutch was properly aligned with a clutch alignment tool.
Old Jul 17, 2011 | 12:39 AM
angeltc's Avatar
Works for me
Old Jul 17, 2011 | 02:27 AM
tom0613's Avatar
make sure the clutch is perfectly aligned
Old Jul 17, 2011 | 04:20 AM
Yes I made sure the clutch was perfectly aligned. Its just getting the tranny level enough to get back to where I can bolt it back on. I'll try again tomorrow.
Old Jul 19, 2011 | 05:04 PM
SandMPerformance's Avatar
if you can lower the engine down a bit more you should be able to get enough room to line the trans back up. its been a while since ive put a trans in a tC, but i do beleive the trans mount might be hangin you up a bit too. but, these are just speculations.
Old Jul 19, 2011 | 06:10 PM
05rs1's Avatar
The motor definatley needs to be at an angle....should be sagging down a bit to get the tranny to pop on...if its str8 it would take you for ever to get the tranny on.....especially alone....grab a friend
Old Jul 21, 2011 | 12:02 AM
Thanks for the tip i'm still messing with it but i took a break. But I will try angle the engine down more. The last time I tried there was 2-3 inches till it hit the engine and it would not move. I'll try again this weekend
Old Jul 23, 2011 | 01:13 PM
Another question... I got the Exedy Stage 1 clutch kit and when I was installing the throwout bearing, I greased it with the supplied grease but it didn't slide on the shaft smoothly. I was wondering if it was suppose to do that. After installing the fork, I can't really move it by hand. Just wondering if that's the way its suppose to be
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
eujin
Feb 23, 2016 01:18 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jeremydoc
Sep 16, 2015 11:31 PM
x2x3
Jul 12, 2015 12:44 AM
