Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Need help taking off caliper
Old Jul 27, 2011 | 11:50 PM
oblivionlord's Avatar
Default Need help taking off caliper
So essentially all that you need to do is take off the 2 14mm bolts behind the caliper to losen up the brake and then you can take off the other 2 larger bolts to remove the caliper completly. However im running into an issue here.... when I twist either of the 14mm bolts... the inner bolt within the slide pin just turns. It looks like this job requires a second wrench probably around 15mm to hold that inner bolt in place.
Is anyone running into this issue?
Old Jul 28, 2011 | 12:22 AM
2tCornot2tC's Avatar
something sounds strange with yours...I had mine off and didn't have to do that.
Old Jul 28, 2011 | 12:58 AM
so im thinking ill need a Cone Wrench such as this illustration suggests....
http://i92.photobucket.com/albums/l3...liperbolts.jpg
Left me find out which way im supposed to twist it? Lefty Loosy, right tighty .. right? If this is the case then im facing the passenger side rotor and im pushing down towards the ground with the 14mm socket wrench. This in term would be the same as lefty loosy. Is this right?
Old Jul 28, 2011 | 01:17 AM
It is a lot easier if you put a clock face on the head of the bolt…turn the wrench clockwise – tighter. Anti clockwise – loose.
Old Jul 28, 2011 | 01:23 AM
well i am diffidently going counterclockwise wise... however when i turn it the inner bolt turns as well. I'm sure at this point that i need a cone wrench just to hold that inner bolt in place because this just doesn't seem to be going anywhere without it.
Old Jul 28, 2011 | 01:37 AM
yup...bicycle wrenches are thin and could work...
evolving_machine
Oct 21, 2023 01:16 PM
RY_TC07
Jul 18, 2017 05:18 PM
PrettySenshi
Apr 13, 2015 05:21 PM
2fixA
14
Aug 26, 2007 05:10 AM
Slopoke21m
54
Apr 23, 2007 12:25 AM
