Painting stock headlight inside
Old Mar 20, 2005 | 09:14 PM
xmetalx's Avatar
Default Painting stock headlight inside
https://www.scionlife.com/forums/viewtopic.php?t=43569
if you scroll down like the 3rd reply theres a few pictures and this guys headlights look AWSOME. My only problem is finding out which paint to use and are there any other ways of getting the lense off without using an oven? any help would be awsome!! thanks!
Old Mar 20, 2005 | 10:54 PM
Max2k's Avatar
You're going to have to oven it. No way around it, really.
Old Mar 20, 2005 | 11:27 PM
xmetalx's Avatar
so uh basically i put it on what temperature....for how long.....on a baking sheet? just the oven rack? use silicon to reseal it? thanks!
oh and whats a good paint to use from my local hardware store
Old Mar 20, 2005 | 11:39 PM
Max2k's Avatar
Just slap that sucker on the oven rack.
250 degrees for 5-6 minutes does the trick. Just put it back in for a minute or two if you're having trouble opening it up.
I didn't reseal it with silicone and haven't had any problems with fogging yet (it's been a while since I did it). I just put it back together and baked it for a bit to seal it up tight.
I just used gloss black Testor's model paint on mine. Someone else used black satin-finish spray paint. It looked pretty sweet, but you have to mask it off with tape.
Old Mar 21, 2005 | 01:32 AM
xmetalx's Avatar
thanks that helped me out perfectly, ill do it probably tomorrow and ill let you know how it goes!
Old Mar 22, 2005 | 02:18 AM
LuminicsBulbs's Avatar
You can use a heat gun to heat them up then make sure that when you put them back together that you seal them completely or you will get all the moisture in there.
Heat gun looks similar to a blow dryer but heats up a lot more. You can get them at Home Depot. I have never heard of anyone putting them in the oven that sounds extremely risky...
Old Mar 22, 2005 | 02:49 AM
Max2k's Avatar
The heat gun screwed up my driver's side headlight. Trust me, the oven method works a lot better.
Old Mar 22, 2005 | 03:04 AM
Lonely_Raven's Avatar
Good to know!
I'm thinking about adding an LED set inside my head lights,
and I have no choice but to open them up for what I want!
Old Mar 22, 2005 | 04:31 AM
Max2k's Avatar
Keep us posted, I always thought it'd be cool to drill a few holes and do white LEDs in the headlights for show.
Old Mar 22, 2005 | 07:49 AM
xmetalx's Avatar
ok so i did it today, i really messed up the rim area where the headlight housing snaps into the lense, but you cant tell when they are in, looks pretty nice. i just wish someone would make some good headlights with some black housing already. the only ones out are trash from what i hear. no pics sorry. the oven thing did work though sweet!
Squishface
Sep 15, 2015 06:51 AM
hampton1100
May 28, 2015 07:32 AM
missing_image
Feb 7, 2015 07:18 PM
TheTripleC
Jan 4, 2015 06:46 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
