throwing codes?!?! help!
i have a greddy ultimate installed. just got tuned. im throwing 2 codes. p0102 and p0037. i have the o2 eliminator in the rear. i have a angled one. i also tried a straight one but still codes comes up for the rear o2 sensor. and for the MAF i cant figure it out. right now i am running recirc. and my maf sensor is before the turbo were it usually is located when your n/a. can someone help me this is so annoying i need to get my car inspected like 2 months ago lol
As far as O2 sensor: i don't have wiring diagram for that- some cars use separate relay and fuse for the heater circuit. If that's not the case with tC, then the only thing that can make ECU detect bad heater is the bad O2 sensor or defective wire.
Electronic component cleaner spray form RadioShack, etc., or MAF sensor cleaner from autoparts store.
well i can help on the MAF sensor cleaner, you carefully (Without touching it) spray the two dental floss looking wires down with MAF cleaner.. CRC sells a good one. And the amber bulb is the IAT (idle air temp) sensor, clean that as well..
OR you weren't asking that?
wayneside
Regional - Pacific Northwest
Sep 23, 2015 10:29 AM
