HIDS
Are you talking about high beams or low beams and are you comparing high beams to low beams or right to left? If you have HID in your high beams, then you simply shouldn't. If you have them in your low beams then they should be roughly the same left to right, but yours are way too far into the blues to be able to see effectively (IMO). White is actually a much better light to see by than blue.
I'm thinking "not likely"... maybe a bad bulb, or a bad ballast, or just not set to the same elevation. With the low lumen output of 10K HIDs, even the slightest difference in elevation aiming will show a heavy degradation in light output. I'll never understand why people go for color over light output when spending the money on HIDs.
As we used to say in the 70's... all show, no go. I don't know if that's the problem here, but it seems plausible.
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
