Can someone recommend an amp for my 2 JL 12W6v2's?
I know that I need something at the JL 1000/1 level, but theyre simply just too expensive. I'm looking for other options or at least an amp that might be more affordable used. I think my absolute highest limit is $400. I've been recommended RD 1000.1, Sundown SAZ-1500D, etc. but they're all still pretty pricey :/
The subs are dual 4 ohm I think, I'm not sure if you can wire them to 1 ohm?
You could wire them down to 1 ohm all together...but an amp that's stable at 1 ohm with enough power usually means $$$.
It may sound stupid, but you might want to also toy with the idea of two cheaper amps. Each one dedicated to each sub wired in parallel which would give you a much broader selection of amps. It might not be better, but its another approach. What's the rms rating on the sub?
Sent from my DROID3 using Tapatalk
Mrp m500 looks like a good idea. Their rated 500w at 2 ohms. Their a monoblock so that means two amps and maybe a few pieces to wire them correctly. Distribution blocks for power and possibly ground. Not a big deal. Their alot cheaper. Look for amps around the 500x1@2ohms
A 1000w@1ohm stable amp is gonna be up their in cost. Runnin 2@2ohms will probably be a better bet. But that's just my opinion.
I have thought about the 2 amp route, but I decided I don't want to do that, nor do I have the space. The JL's eat up the entire trunk. If the 2 JL's can for sure be wired to a 1 ohm load, that would open some options for me. Is this for sure possible? Some places I've read you can, others have said they can only do 2 ohm or 8 ohm.
Yes if their dual 4 ohm you can wire each speaker to a 2ohm load. (+ to + then - to - ) on each speaker from there you'd connect one positive terminal from each speaker to the + on the amp. Both negatives to the neg on the amp. That would then split the 2ohm load from each speaker down to a 1ohm load going to the amp
So yeah, I'm basically looking at an amp to power a 1 ohm or 4 ohm load, as that's the only two they can be configured to. Is there any disadvantage towards using 1 ohm or 4 ohm? I have heard that the higher the ohmage, the cleaner and more accurate the tonal SQ will be on the subs, which is something I would not like to sacrifice.
I was looking at this Fosgate.
But honestly, there are some refurbished JL 1000/1's out there for a little over $400, and if I was going to spend that much, I could have 1000 watts at 4 ohms rather than at 1 ohm with the Fosgate.
Yes typically the higher the ohm load the better the sound quality. But it falls into the same category as performance parts. A high quality 1ohm stable amp may sound better than a ____ty amp running 4ohms. The refurb jl amps probably aren't a bad idea. But you do run that risk ya know? Im a fan of alpine but a $400 1000/1 ain't bad.
Would you guys say that I need a new battery or alternator with my setup now? I'll have 2 12w6's on the 1000/1 and Focal 165v2's as the components (rated 75 rms each).
Should I consider upgrading anything else yet?
