2011-____ [ANT20]
Sideview mirrors heat...
Old Oct 4, 2011 | 09:09 PM
chicagokid's Avatar
Default Sideview mirrors heat...
Has anyone tried putting on some kind of heating element on the back of the side view mirrors? Or replaced the mirrors all together with different ones that heats up? I am looking to do this either by having heat turn on when rear defroster is turned on or independent on/off switch. Is this possible with the OEM mirrors? Thanks guys.......
Old Oct 5, 2011 | 07:43 AM
Scion202's Avatar
sounds useful but dangerous as ____ lol
Old Oct 5, 2011 | 11:22 AM
chicagokid's Avatar
Is this a bitc_ to do??
Old Oct 5, 2011 | 01:09 PM
Scratch's Avatar
You would have to find a car with a similar sized mirror, buy the assembly, including power to adjust the mirror, and somehow mount it in your housings. There may also be glass cutting to make it match up... seems costly to accomplish. I usually just slapped some rain-x on the mirror and most of the condensation just wiped right off in the mornings.
I do understand the want though... heated mirrors on my Passat are the shiz.
Old Oct 5, 2011 | 04:03 PM
cobaltbravo's Avatar
Or, you use the heated elements that go on snowmobile handles. You have to remove the mirror lens itself, clean of the adhesive from both surfaces, the element would be samwiched between the mirror and the assembly with industrial adhesive, then wire the element thru the door to either a switch in the dash, or if you know the wiring involved in the hvac panel, you could possibly wire it into the defrost button. Its been done on xDs.
Sent from my rooted Droid
Old Nov 25, 2011 | 03:33 AM
KyleG's Avatar
Well, I'm not sure about USA, but my Canadian TC has heated mirrors standard.
http://www.scion.ca/scion/vehicles/t...tions/exterior
Don't mean to dig up an old thread, but this came up as I was trying to search if my Tc had heated mirrors, so hopefully this will useful to others.
Old Nov 25, 2011 | 01:49 PM
ronald2's Avatar
Whoa really?? I had no clue my tc has heated mirrors, do they just activate with the defroster button?
Old Nov 25, 2011 | 02:43 PM
KyleG's Avatar
Yep, just hit that button and they come on
Old Nov 25, 2011 | 03:41 PM
dm1336's Avatar
Yup we got them up here.
It's weird because the rear defog button doesn't say that it's for the mirrors too but it is!
Old Nov 26, 2011 | 09:20 AM
Rotz's Avatar
Man Canada got everything. Rear wiper, DRL's, vent visors, heated mirrors......
Old Nov 26, 2011 | 11:25 AM
dm1336's Avatar
Which is weird because normally we get cars with less features than US models for a lot more...
The tC is more but at least what we get with ours is worth the price difference (including exchange rates)
Maybe Toyota wanted to do something good for it being the first year for Scion in Canada.
Going back l the original question (if anyone is still following)... Now that we know the tC can come with heated mirrors we just need to find the part # and wiring diagram!
Old Nov 26, 2011 | 01:27 PM
dpanda88's Avatar
i don't think Canadian TC have heated side mirrors. Doesn't side mirrors usually have the symbol on it to indicate that it does have it?? Like on the bottom left or right corner?
It was froze up the past couple of days and I turn on my heat and the side mirrors were not getting de-frosted....
The symbol is this one...
Old Nov 26, 2011 | 01:59 PM
dm1336's Avatar
Not all cars have indicators on the mirrors.
My parents have a 2004 Odyssey and a 2006 Accord and they don't have any indicators on their side mirrors when it's activated. Although they do have a separate button for the side mirrors.
For the tC the heated side mirrors button is the same one for your rear glass which is on the center control **** for the HVAC fan speed. Push that button and both side mirrors and rear glass are on. Try it next time it's frosted up in the morning.
btw.. no TPMS on our tC's sold up here
Old Jan 5, 2012 | 03:23 AM
jasminemarie's Avatar
I just park in my garage. 👍 noo need for heated mirrors.
Old Jan 5, 2012 | 05:08 AM
VVTinme's Avatar
I'd much rather have heated side mirrors than TPMS. Tires naturally lose air pressure over time and require periodic maintenance. I check my tire pressure around once a month, adding air as necessary. I have had times where my mirrors had frosted over and it's been an annoyance not having heated mirrors. You guys also have a rear wiper, another nice feature.
alexdrummerr30
Sep 8, 2018 12:18 PM
hondajt
Dec 14, 2015 12:54 PM
iFangy
Scion tC 2G ICE & Interior
Aug 20, 2015 06:16 PM
Mica09
Jul 25, 2015 05:28 PM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
