Comfort vs. Performance
Old Oct 20, 2011 | 09:07 PM
JMANTC's Avatar
Default Comfort vs. Performance
I've been debating to myself for awhile whether I should go for more of a comfort setup versus a performance setup coilover.
I see that the TRD coilovers provide a comfortable ride and adds a sportier feel in the ride's suspension. However I think these may be lacking a little too much on the performance side.
But then again, I don't want too stiff of a ride where I will be in pain on some bumpy roads out here or start feeling that highway I once thought was smooth actually is not the case.
What is the next step up from the TRDs that has a good balance between performance and comfort? Would those be the Tein SSs?
Old Oct 20, 2011 | 09:25 PM
Roller_Toaster's Avatar
I have been told that the Ksport kontrol coilovers are similar to just springs when set to their softest setting. Also, they are dual TAP, which means you can change the ride height without affecting spring rate and shock travel (which results in crummy ride quality).
Old Oct 23, 2011 | 05:16 AM
mrexotica's Avatar
If you want your car to handle,
#1 mod: put the fattest rear antisway bar on. Either a DG Spec or Hotchkis Sport.
Your handling will improve hugely.
I auto crossed my tC for almost a year with no suspension mods other than rear sway bar and I was competitive.
Antisway bar will not make your ride harsh either!
Old Oct 24, 2011 | 07:51 PM
JMANTC's Avatar
INTERESTING. I will definately get the sway bar thanks.
I guess coilovers don't make as significant a performance change as most people think. Mostly for the looks on the drop and to save your stock shocks.
edit: Where can i buy the DG spec sway bar?
Old Oct 25, 2011 | 11:30 PM
mrexotica's Avatar
Absolutely!
Try Dezod. He sponsors DG Spec (Dan Gardner)
Dezod also makes some super-nice end links for rear sway bars.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
prescottn
Sep 13, 2015 09:04 PM
ScionLife Editor
Sep 8, 2015 07:10 PM
