Replacement Keys at Walmart
Old Jan 6, 2012 | 08:50 PM
miggity79's Avatar
Default Replacement Keys at Walmart
Apparently Walmart now programs keys. Cost me $60 to get a replacement key with a transponder. No alarm, but you can probably just take the transponder out and do a DIY switchblade swap.
Old Jan 6, 2012 | 08:55 PM
SquallLHeart's Avatar
afaik.. it's not the key they need to program... it's the car's ECU..
so.. i don't know how that's gonna work..
Old Jan 6, 2012 | 09:30 PM
miggity79's Avatar
i think that only happens if you lose ALL your keys. i took in my valet key and they copied the transponder code to a new key.
now i can work on losing my 3rd key.
Old Jan 6, 2012 | 10:13 PM
thendawg's Avatar
yea supposedly they started rolling this out about a year ago. I dunno if any of the stores around here have it, but I was doing a remote start job for a guy in TX a little while back, and he had walmart "clone" a key for his Tundra for me to use for the remote start key box. Basically the dealership takes a key with a preset "code" on the chip in the key, they than program the car to recognize this new code as valid. Walmart's new machine somewhat reverse engineers the process, it reads the code from an existing, working key, than duplicates that code to another key, so when you use the new key, the car still thinks its the same one its used to. Works great if you just need another key, not so great if youve lost all your keys and dont have one to duplicate In that case, youd need the VIN and would have to go with your title to the Toyota dealership and have one cut and programmed to the car.
Old Jan 7, 2012 | 02:51 PM
interesting... i can't say i've ever heard of such a process...
.. but that would be the only method where I can see making it possible.
Old Jan 7, 2012 | 04:36 PM
ROCKLANDTOYOTA's Avatar
we've been doing this for a couple of years now with new cars and aftermarket remote starts.....
Old Jan 7, 2012 | 06:03 PM
jono06tc's Avatar
I should look into this, ever since i switched to the switch blade key 've had problems with starting the car. Sometimes it takes my 5 tries until it recognizes the key and decides to start, or at least i think thats the problem
Old Jan 9, 2012 | 05:22 AM
JahJosef's Avatar
So now Walmart is going to put us little guys out of business. We've been doing "i" keys since '07, along with "P" keys and "A" keys. "I" keys are duplicates of the original, GM "P" keys have to be programmed to the vehicle and require nothing else, "A" keys force you to go out into the car to "burn" a code from the car onto the new key, then return to the computer programmer to complete programming obtained from a remote server.
Or this is what I follow form my 3 years of programming/selling chip keys. Not 100% sure. Only have had issues with Nissan/Infiniti for some odd reason, RMA the key and get back to business.
Old Jan 9, 2012 | 06:50 PM
miggity79's Avatar
heres a pix of the key.
def wont fit the transpoder spot in the stock key. probably wont fit in an aftermarket key either.
Old Jan 20, 2013 | 07:25 AM
keyman's Avatar
I can copy your key onto a transponder chip that's identical in size to the oem chip. Send me a message.
Old Jan 20, 2013 | 09:38 AM
Dam262a's Avatar
This thread is over a year old I doubt they need that.
Sent from Tapatalk HD
Old Jan 21, 2013 | 09:24 PM
keyman's Avatar
Just checking. Someone might find it while doing a search.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
Nicolewelker22
Jan 14, 2015 01:08 PM
cid_mcdp
Jan 5, 2015 02:45 PM
