Rear rims/tires with spacer rubs fender
Old Jan 13, 2012 | 12:46 AM
danman2_2999's Avatar
Default Rear rims/tires with spacer rubs fender
I've bought 18" rims for my 2004 Release Series 1.0 xB but noticed the front wheels sat wider than the rear. So I ended up buying some wheel spacers to bump the rear out a bit. Unfortunately they rub from time to time when I drive, so I ended up removing them and just leaving the stock rim/tires on.
How can I get the inside of the rear fender (the inner lip) removed/shaved down without having to remove the entire fenders or repaint them? Is that even possible?
Thanks,
Daniel
Old Jan 13, 2012 | 01:42 AM
aryana159's Avatar
rolled the fender with a fender roller. google it will show you the tool i have one but im located in texas it bolts up to your wheel hud with a arm and it folds in the lip to give you the extra clearance needed.
some performance shops will roll it for you usaly from 50-75 a side.
Old Jan 13, 2012 | 01:58 AM
itscurtsk's Avatar
or MAYBE you can exchange your spacers for smaller ones ....
Old Jan 13, 2012 | 01:59 AM
Thanks for your help. Yeah I see now that is what I need. I am trying to find somewhere local who does this service, as I do not feel comfortable enough to rent one and try it myself.
I am hoping someone in the Los Angeles area will see this and refer me!
Thanks again!
Old Jan 13, 2012 | 07:58 AM
itscurtsk's Avatar
craigslist.
Old Mar 1, 2012 | 04:26 AM
Thanks for the advice! I ended up having a kid from craigslist do mine for 50 bucks, which solved the rubbing problem.
Thanks again!
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
scionlife
371
Jun 2, 2015 11:00 PM
pdxgen2
Scion xB 2nd-Gen Wheel & Tire
Mar 14, 2015 01:56 AM
terrye
Jan 25, 2015 05:31 AM
toyotaisme
Jan 10, 2015 10:24 PM
