Rear rims/tires with spacer rubs fender
I've bought 18" rims for my 2004 Release Series 1.0 xB but noticed the front wheels sat wider than the rear. So I ended up buying some wheel spacers to bump the rear out a bit. Unfortunately they rub from time to time when I drive, so I ended up removing them and just leaving the stock rim/tires on.
How can I get the inside of the rear fender (the inner lip) removed/shaved down without having to remove the entire fenders or repaint them? Is that even possible?
Thanks,
Daniel
Thanks,
Daniel
rolled the fender with a fender roller. google it will show you the tool i have one but im located in texas it bolts up to your wheel hud with a arm and it folds in the lip to give you the extra clearance needed.
some performance shops will roll it for you usaly from 50-75 a side.
Thanks for your help. Yeah I see now that is what I need. I am trying to find somewhere local who does this service, as I do not feel comfortable enough to rent one and try it myself.
I am hoping someone in the Los Angeles area will see this and refer me!
Thanks again!
Thanks again!
scionlife
371
Jun 2, 2015 11:00 PM
