Bottom protection for xA
Old Jan 26, 2012 | 04:08 AM
MidnightScion's Avatar
Default Bottom protection for xA
I don't know how much interest it would generate.
HERE thery are, skid plates for engine/transmission (1/4 inch aluminum plate) and brake/fuel lines(1/8 steel plate) Name:  photobucket-7942-1326536045905.jpg
P.S low profile H-frame is in the workings, rear frame brace is in place (not shown on this pic)
Old Jan 28, 2012 | 01:37 AM
Russ Lyman's Avatar
Looks sturdy.
Sent from my iPhone using Tapatalk (sweet!)
Old Jan 28, 2012 | 03:08 AM
HotrodPez's Avatar
Don't trust the lower radiator core support strength. It is flimsy. I'm building a whole steel tube subframe for my car to solve that problem lol
Old Jan 28, 2012 | 04:30 AM
Russ Lyman's Avatar
What car do you drive.
Old Jan 28, 2012 | 06:11 AM
the radiator support has no load bearing (according to my floor jack test. most weight is supported by subframe.
when using 1/4 inch aluminium plate there isnt much give anyways. besides I'm not going to use it rock crawling ;-}
thanks for the tip though, always appreciate a valid input ...
P.S it is 05 scion xA ...
Old Jan 29, 2012 | 07:32 AM
HotrodPez's Avatar
It will definitely help save your transmission pan when you nose-dive into a dip. But you'll probably ruin your skid plate. That's what it's for, right!
Old Jan 29, 2012 | 10:59 AM
I have already put two nasty gauges in both oil pans while exploring Pacific Northwest trails couple months ago.
I doesn't seem to bottom out on streets, so no worries there!
On a trail there is a huge difference between punctured pan, no oil in slush box or worse loss of oil in the engine and getting home tired but happy after a day trail blazing!
P.S
Same applies to brake/fuel lines and steering hoses which are completely covered by rear part of the front skid plate...
Old Jan 29, 2012 | 10:45 PM
Russ Lyman's Avatar
Yeah I don't do any off roading so I should be ok. Sounds like a good idea.
Old Feb 2, 2012 | 02:33 AM
Distracted_Thinker's Avatar
Doesnt beatrush make and under panel?
Old Feb 2, 2012 | 06:12 AM
From what I can tell by looking at what they make, its just a dust shield not a skid plate. It appears to look thinner than 1/8 of an inch! What will it protect ?
I can lift front end on the skid plate I put in with little deflection of it.
And the beauty of it was, it only cost me a mere $75 + some fabrication time...(free of charge for me from me)
Not that it will completely protect oil pans, but it presents a chance of survival if
struck by something larger than a random parking lot pebble.
Cheers
torqueTc
Oct 8, 2015 05:39 PM
scionsux
Sep 2, 2015 05:30 AM
carid
Aug 7, 2015 11:32 AM
