HELP!!!!
Old Feb 7, 2012 | 04:25 PM
tCJennyfer88's Avatar
Default HELP!!!!
So I bought a carbon fiber short antenna go my tC and after I put it on my stations are all fuzzy... Is there anything I can do to make them work???
Sent from my ADR6300 using Tapatalk
Old Feb 7, 2012 | 04:33 PM
GQQSE13's Avatar
different antenna lol; most aftermarkets were more so for look and sort of make the quality worse
Old Feb 7, 2012 | 04:35 PM
Esh Darkstar's Avatar
Not to sound like a jerk but put the old one back on. This is to make sure it is the antenne and not something else. IIRC radio shack does sell an antenne booster that should help but this is always a problem if you shrink your antenne without compensating for that.
Sent from my Galaxy Tab using tapatalk
Old Feb 7, 2012 | 04:36 PM
DJ08tC's Avatar
antenna probably just sucks! you should switch s2000 one.
Old Feb 7, 2012 | 04:38 PM
But it looks so much better.... The old one I had on there had the rubber all peeled off and I didn't like the way it looked... Any other antenna I can buy that looks good AND works lol
Oh and you don't sound like a jerk... Lol you are just helping and got that I thank you
Old Feb 7, 2012 | 04:47 PM
DJ08tC's Avatar
a s2000 antenna, it is short and it works!
Old Feb 7, 2012 | 04:59 PM
Lil_Deuce_tCoupe's Avatar
Pretty much every 'stubby' antenna like that is the same, no reception.
Yup, S2000 is the way to go - it's the antenna used on the Honda S2000, available at a Honda dealer, on ebay, or sometimes for sale here in the classified section.
Be careful though, there are fakes. Most expensive option, but going to the dealer insures you get a real one.
Old Feb 7, 2012 | 05:09 PM
So an actual factory s2000 antenna will fit ?? Or after market
Old Feb 7, 2012 | 05:19 PM
TTCCC's Avatar
Adds 5 HP.
Old Feb 7, 2012 | 05:22 PM
Get a factory one. Honda Element antenna fits also, same length as the S2000.
Old Feb 7, 2012 | 05:43 PM
JimHudsonScion's Avatar
I'll trade my factory one that's in fine condition if you want... =D I never listen to the radio, so it doesn't matter what it sounds like to me.
Old Feb 7, 2012 | 06:32 PM
SquallLHeart's Avatar
Toyota also makes shorter antennas too... i have a thing putting Honda parts on my car... so I found one from a Toyota Matrix that fits perfectly.
Old Feb 7, 2012 | 06:42 PM
Where do you live
Old Feb 7, 2012 | 10:55 PM
Syldrin's Avatar
thanks for this squall. but what year?
Old Feb 8, 2012 | 03:04 AM
TheMuffinMan00's Avatar
I have the exact same antenna. The problem comes from the fact that the whole mast is metal instead of just the threaded part covered in rubber.
So that makes the metal antenna ground out on the outer ring metal piece that it shouldn't touch. If you cover the metal ring with black tape then screw it in lightly so it doesn't break through it picks up a little better but still not like the factory antenna would. My car came with this one and I just ordered the s2k antenna off of ebay because I usually do listen to the radio and travel a lot and with this antenna I get a lot of dead areas.
Old Feb 8, 2012 | 04:34 AM
creamyxb2's Avatar
i use a 02 Acura mdx anntanna. it was 12.00. it may be the same as a s2000. i never crossed the number to check.
Old Feb 8, 2012 | 04:56 AM
mine came off a 2009 Matrix.
Old Feb 8, 2012 | 05:51 AM
Rezzle00's Avatar
2nd this.
Old Feb 10, 2012 | 02:46 AM
Where do you live
PM'd
