12v under hood for LED?
Old Feb 15, 2012 | 11:42 PM
testa422's Avatar
Default 12v under hood for LED?
is there a good place to wire up some leds under the hood? i tried splicing into the parking lights and the leds wouldnt work for some reason. not a fuse problem bc park lights still work!?
Old Feb 16, 2012 | 04:54 AM
stankyrice's Avatar
Directly into the battery w/ a fuse and just run a switch through the firewall, so that way you can turn it on and off from inside the car.
Old Feb 16, 2012 | 02:52 PM
testa422's Avatar
well it has a remote for on/off...so just put an inline fuse and then straight to battery?
Old Feb 16, 2012 | 07:46 PM
stankyrice's Avatar
yup, for grounding, you could go to the battery if wires are long enough, if not just ground it to any bare metal.
Old Feb 16, 2012 | 10:57 PM
mxyooji's Avatar
if you spliced correctly they would work; whatever method you used to "splice" probably didn't make enough contact on the wires. btw, the green wire = positive wire iirc.
as for the ground you can also splice that into the neg wire as well or ground to any metal point.
Old Feb 16, 2012 | 11:06 PM
testa422's Avatar
thanks guys...yea the directions say splice into a positive and a negative
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
umnitza
Sep 1, 2015 08:06 PM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
umnitza
Aug 21, 2015 12:35 AM
StxArOne
Jul 13, 2015 06:25 PM
