12v under hood for LED?
is there a good place to wire up some leds under the hood? i tried splicing into the parking lights and the leds wouldnt work for some reason. not a fuse problem bc park lights still work!?
if you spliced correctly they would work; whatever method you used to "splice" probably didn't make enough contact on the wires. btw, the green wire = positive wire iirc.
as for the ground you can also splice that into the neg wire as well or ground to any metal point.
umnitza
Sep 1, 2015 08:06 PM
umnitza
Aug 21, 2015 12:35 AM
