Cant use Aux port 2008 tC
Old Feb 21, 2012 | 01:09 AM
jncs713's Avatar
Default Cant use Aux port 2008 tC
I just bought a tC 08 and I'm trying to use the Aux port but can't hear and I when I push the Aux button on the stock radio nothing happens...
please help if any knows. what's up thnx
Old Feb 22, 2012 | 10:30 AM
sciontc_mich's Avatar
Originally Posted by jncs713
I just bought a tc 08 and I'm trying to use the aux port but can't hear and I when I push the aux button on the stock radio nothing happens... please help if any knows. what's up thnx
try hooking up something to the cable (3.5mm stereo male to male), inserting it into the aux in (in the armrest) and then turning ON the mp3 player, ipod, etc you're trying to input into the aux in.
the headunit will not work for AUX unless it sees voltage/signal in the aux in port, this is only accomplished by turning the portable (mp3, ipod, etc) on.
that's how it will finally work..
Old Feb 27, 2012 | 06:22 AM
mrjtang's Avatar
JNCS- welcome to the forum. yes, you need to have something plugged in - such as an MP3 source in order for the Auxilary to work.
Old Mar 3, 2012 | 03:44 PM
xxFlyingArmBarxx's Avatar
i was having the same issue with mine using the AUX to plug in my phone. The only way it would read it is if i plugged in my car charger while the AUX was hooked up.
Old Mar 10, 2012 | 09:12 AM
andyc0313's Avatar
Assuming you have it plugged in at both ends and said device is powered on and playing music, you should hear something out of your speakers when AUX is selected on the hu.
Old Mar 12, 2012 | 07:44 AM
marcossolares's Avatar
Yea or it might be a short inside the actual port that it hooks up to
Old Aug 2, 2016 | 01:13 PM
JJDice's Avatar
is there a way around this? I also can't go into aux mode unless my ipod is charging via the cigarette lighter. would grounding the aux input fix this?
Old Aug 2, 2016 | 07:53 PM
yes it's very simple. Get yourself a ground loop isolator, 3.5 mm input/outputs. About $10-15. That will stop the problem. It's easier than trying to re-engineer the electrical grounding of the tC.
PAC SNI-1/3.5 (sni135) 3.5mm Ground Loop Noise Isolator Works W/
they're available all over, I just like the PAC model.
Old Aug 8, 2016 | 03:19 AM
SatsumaxA's Avatar
Scion T1807 install in 3rd gen '99 Limited (pic heavy) - Toyota 4Runner Forum - Largest 4Runner Forum
look here too..
Pkdust
Oct 20, 2015 04:27 PM
Schmohey
Oct 4, 2015 02:53 PM
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
JonnyBigBoss
Sep 26, 2015 08:31 PM
