Car having trouble starting. Not an engine guru so any help would be cool
Old Feb 27, 2012 | 01:07 PM
JaCqEeZ's Avatar
Default Car having trouble starting. Not an engine guru so any help would be cool
Went to start my car this morning and it turned on then imediately turned off. Couldn't get it to start after that. Checked the battery and everything looked good. So as I tried to start it again, I started pumping the gas and it started up but then shut off again. So i did it again and stayed on the gas a bit so it wouldnt shut off and it stayed on. I let it run for like 5 minutes then took it for a drive and it seemed fine. Is it the fuel pump or will it not run if the fuel pump is shot? Also, I had a 1/4 tank of gas and wasn't on any big incline or decline. Any help would be cool.
Old Feb 27, 2012 | 02:04 PM
Spicy_McHaggiz's Avatar
Fuel pump would mean it wouldn't start at all.
Check your idle air control valve.
Old Feb 27, 2012 | 02:45 PM
engifineer's Avatar
It is possible for a fuel pump or fuel pump relay to intermittently fail at first.
And pumping the gas does absolutely nothing on a fuel injected car before startup.
Old Feb 27, 2012 | 03:49 PM
my06tc's Avatar
how about your maf sensor.....just a thought
Old Feb 28, 2012 | 12:55 PM
JaCqEeZ's Avatar
thanks for the replies. and yea engifineer thats the first thing my buddy said when I asked him. The car ended up starting up fine all day. Then this morning it didn't fire up like normal but it still fired up, so something is about to go. I guess it is just when the engine is cold.
BV19869
Dec 11, 2014 06:05 PM
rcflyer15
Dec 5, 2014 05:15 PM
eric_m
79
Mar 17, 2013 12:21 AM
Risen_Son_Racing
May 6, 2005 02:31 PM
tC_Normo
Oct 22, 2003 07:20 PM
