Leave car running
Old May 3, 2012 | 06:40 PM
cveklund's Avatar
Default Leave car running
I want to be able to start my 06 xb and flip a switch to keep it running then I take the key out. Kinda like a remote start but I have a mt. Any ideas on how to do this?
Thanks,
Chris
Old May 3, 2012 | 08:44 PM
rfknvan's Avatar
The newer DEI remote starters have a manual trans option, that would be my recommendation. If you want to try and do it yourself you will want to have a good amount of 12volt wiring knowledge and the use of relays and how to interact them together. That sounds like a fun project but if you want simple then I would just buy a DEI brand remote start.
Hope this helps
Old May 3, 2012 | 10:19 PM
x_Batman_x's Avatar
Yeah, i use my Viper alarm like a turbo timer. When I finish my drive I press the brake, pull up the ebrake, release the brake and then press a button I put on the switch panel. I can then pull out the key and the car remains running. I can get out and lock the car and it remains running until the programmed time runs out or until I turn it off using a button on my remote. Then, as long as I dont open a door before-hand, when I return to my car I can remote start it.
Old May 5, 2012 | 12:33 AM
cveklund's Avatar
Is there directions somewhere on how to install one? It's been years since I installed one and I had help of an installer then.
Old May 10, 2012 | 03:54 PM
Forklift's Avatar
you could just wire a switch to control a pair of relays to keep ignition and acc on (for ac/heat)
cid_mcdp
Jan 5, 2015 02:45 PM
ScionRo
Jan 2, 2015 07:54 PM
baker08tc
Dec 30, 2014 12:02 AM
hotroddelux
Dec 3, 2014 11:33 PM
tC_Normo
Oct 22, 2003 07:20 PM
