Replacement Negative Battery Cable + Terminal
Old Jun 11, 2012 | 07:25 AM
richardsayzz's Avatar
Default Replacement Negative Battery Cable + Terminal
So after 6 years it seems my battery has finally died... upon changing it I noticed that blue corrosion stuff that I normally clean. When taking out my old battery the terminal literally snaps off the cable and I see blue corrosion has eaten into the wire.
Would it be easy to change the negative battery cable or should I have some tech do it. I've installed an intake and changed the pads on my car but never done any electrical work.
Where can I get a replacement battery + terminal that would bolt right on since I have no soldering equipment and such?
___
Old Jun 12, 2012 | 04:28 PM
abraves4410's Avatar
Easy to do. all you need is a short run of wire, two ring terminals, and that's about it.
Look up a DIY on the Big 3 and that'll give you an idea.
For quality wire I would look into Knuconceptz, or just hit up a local shop
___
Jaci121
Feb 24, 2017 10:33 PM
muuunkeeyy
May 30, 2013 01:00 AM
lukeyd900
Scion tC 1G ICE & Interior
Jan 29, 2010 10:31 AM
JoeDarkness
Jan 17, 2006 04:33 PM
twoturntables
Jul 12, 2004 03:30 AM
