Bad negative battery terminal and cable.
So apparently my cable and terminal are bad for the negative. The positive is perfectly fine so I was wondering if it was possible to upgrade to a ground wiring kit?
http://www.ebay.com/itm/NRG-RED-GROU...3952b1&vxp=mtr
I know these are debatable as good, but I thought I would be able to use this problem as a reason for an upgrade of some sort. I know making your own would be good, but I would rather have it come nice looking than a bunch of random wires I put together.
i actually got a new battery and replaced the battery cable terminal. the negative cable had corrosion buildup that started getting into the wire. i cut the corroded parts off the wire before attaching a new terminal.
revalina
12
Dec 27, 2022 04:21 AM
