Steering Wheel Control Adapters
Old Jun 22, 2012 | 03:42 PM
rayx22's Avatar
Default Steering Wheel Control Adapters
I'm installing a Pioneer AVH-2400bt in my 2007 Scion tC. I'm trying to come up with the best way to still be able to use my steering wheel controls with this aftermarket stereo. I've looked into the Axxess ASWC and the PAC SWI-PS. For anyone who has installed either of these in their Scion, are they easy to "undo," if I decide to get rid of the car and put the factory stereo back in? (I'd like to retain that option, if possible.) Thanks in advance for any input!
Old Jun 22, 2012 | 04:13 PM
GQQSE13's Avatar
there's quite a few who'f used the PAC wired one, to undo if you decide to ditch the unit shouldnt be bad. it would just be clipping wires and then sodering them back to the way they were before. i've never done it but im guessing that's all that needs done
Old Jun 23, 2012 | 02:06 PM
Jonny5ive's Avatar
I am in the process of installing an AXXESS unit with my aftermarket head unit...seems easy to understand. I'll let you know how it goes in a couple of days.
Old Jun 25, 2012 | 06:43 AM
pyrophire's Avatar
I installed the Axxess into my tC with my Pioneer AVIC-X940BT and it was a fairly simple install. I had a bit of a problem which ended up being a bad ground to the stock harness. Once tech support advised me to move it, it worked great. It has no delay and doesnt need to be programed, works just like the stock one, except you can fast forward thru songs.
Old Jun 25, 2012 | 10:16 PM
rayx22's Avatar
Thanks for the input, everyone!
Pyrophire - If you had to take the Axxess out to put the stock headunit back in, would it be fairly straightforward to do?
Old Jun 25, 2012 | 10:18 PM
pyrophire's Avatar
As long as you dont cut the wires in the car's harness, just tap into them, it should be fine.
evolving_machine
Oct 21, 2023 01:16 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Beesh
Jan 9, 2015 06:30 PM
