Scion iQ Aero & Exterior Aero parts and exterior dress items...
Convert Fog Lights To DTRL
Old Sep 4, 2012 | 07:06 PM
mike1948's Avatar
Default Convert Fog Lights To DTRL
NOOB here!!
Just picked up my 2013 IQ and found out that there are no daytime running lights:?. I am getting foglights installed at the dealer next week, can they be converted to daytime running lights? I guess what I would like them to do is come on when the engine starts and be on all the time except when the high beams are active. We have alot of deer activity at night around here and I need all the extra light I can get. It might even be good to have the option to have them on with the high beams active???
Can this be done?
TIA
Mike
Old Sep 4, 2012 | 10:34 PM
user 7208230's Avatar
I'm not sure but this might be a start for you. http://clubsciontc.com/forums/diy-in...ersible-30214/
Or PM surfcitylocal maybe he has some info.
Old Sep 5, 2012 | 01:17 PM
surfcitylocal's Avatar
The method used on clubsciontc looks like it would work great.
Old Sep 5, 2012 | 08:28 PM
mike1948's Avatar
I just found a install PDF file for the 2012 IQ and there is no wiring harness provided with the fog light kit, only the relay. If I go with the standard install do you have to turn the fog lights on everytime you start the car? Will they come on without the headkights operating?
I have bad CRS and would forget half the time.
Mike
File Type: pdf
Old Sep 6, 2012 | 03:15 AM
I have the factory fog lights, they come on when you start the car and turn off when you lock the doors (double click on remote)
Old Sep 6, 2012 | 12:22 PM
mike1948's Avatar
Thanks for the info, I guess I won't mess with the standard wiring.
Mike
Old Sep 12, 2012 | 08:13 PM
mike1948's Avatar
Just got my IQ back from fog light install at dealer. They only come on when the low beams are on, not when you start the car. They go off with high beam as I expected.. and off with switch or double click of lock.
So now I'm back to my original question: anyone know of a way to mod them so the fogs(with switch on) come on with engine start. Then go off with engine off or, switch off? Even with high beams.
I hope there is help out there somewhere!!!
TIA
Mike
Old Sep 13, 2012 | 12:42 AM
You would need to locate the power in lead to the fog light switch and change it to a power source that is on when the key is in the ACC or ON position. If you do that the high or low beams will have no effect on them.
Old Sep 13, 2012 | 01:39 PM
mike1948's Avatar
Just an update. I forgot to shut off the lights fogs and headlights, and to my surprise they shut off by themselves in about a minute, no key click required. Also with all the switches stil in on position restarted car and all lights came back on.
So I guess I have "sort of" DTRLs but with tail lights also. I'll run with the low beams and if I really want to light up the little thing hit the fogs also. Plus I don't worry about forgetting to shut them off. I can live with that.
Mike
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
