Open rear door with dead battery?
Old Oct 12, 2012 | 05:15 AM
Greasyman's Avatar
Default Open rear door with dead battery?
Is there a way to do it. My battery is fine, but I want to know, just in case. Also, is there a way to open the rear door from the inside?
Old Oct 12, 2012 | 12:20 PM
Jan06xB's Avatar
Reminds me of the Prius only with the Prius the battery is in the trunk so you can't charge the battery unless you can open the trunk and you can open a trunk because the battery is dead. So they actually give you a jumper point under the hood. I think you're out of luck if the battery is dead, no way to open the door.
Old Oct 12, 2012 | 04:05 PM
Greasyman's Avatar
So if your battery cables are in the storage area next to the spare tire, you can't open the door to get at them. Instead, you need to open the rear door, fold down the seat, crawl back there, open the storage area with the lid towards you, and try to reach down and get them. Might be easier to do than I imagine, but it seems using a normal mechanical latch would have been easiest. What's the point of an electric lock?
Old Oct 12, 2012 | 05:06 PM
JIMXB's Avatar
Most likey to cut down on costs??? Manufacturers alway seem to do it on the most likely thing needed, that we think would only cost a couple of dollars more to do.
I never understood when the 2nd gen xB came out, it only had one reverse light in the left bumper. Why would they not also put one on the right side also for equal lighting + symmentry. To me it was a major eyesore + hated the 2nd Gen because of that stupid design. Who knows??? It must have been to cut down costs.....:?
Old Oct 12, 2012 | 05:57 PM
Big_Jim's Avatar
I responded on the other site. peep the answer there lol
Old Oct 12, 2012 | 07:51 PM
JIMXB's Avatar
What's the other site link to peep for the peeps to peep at your phenominal answer????
Old Oct 12, 2012 | 11:35 PM
Roller_Toaster's Avatar
I <3 my bright ___ single reverse light. :D
Old Oct 13, 2012 | 02:21 AM
DaWiz711's Avatar
Lol I just read both threads at ClubxB.com, then came over here and was like wtf?
For those who search and find it here, you can manually open your hatch if you pull that interior panel off. There is a small red lever you pull to open it. There is a DIY for a manual override over at ClubxB as well. Cheers!
Sent from the Satellite Of Love via Gypsy
Old Oct 13, 2012 | 03:42 AM
Greasyman's Avatar
Thanks Wiz. I figured I'd cover all the bases.
Old Oct 13, 2012 | 03:50 PM
Jan06xB's Avatar
Good to know but pull the panel off? Sounds like a lot of work ...
Old Oct 14, 2012 | 10:24 PM
buickid's Avatar
Our '04 Sienna has a plastic door in the middle of the panel to access the manual release. For what its worth, it hasn't failed once yet, with quite a bit of use.
Old Oct 15, 2012 | 01:40 AM
Jan06xB's Avatar
I read that there is a problem with the outside latch handle coming off.
wwotr
Mar 28, 2015 01:47 AM
CPL_Radar
Mar 5, 2015 05:42 AM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Kiwibox
Dec 15, 2014 09:46 PM
